20 Most Recent
Toyota Hilux Questions & Answers
How do i solve my problem car won t start.
Which year Hilux is this? The newer models are using an ECU which controls the injection. There are quite a number of different inputs made by various sensors to the ECU, which calculates the correct amount of diesel to be injected. If any of these sensors are faulty or not giving a reading, it wont inject the diesel, causing it not to start. In this event it will be better to have it plugged to an OBD reader to point you in the right direction.
2/3/2018 5:44:37 AM •
Toyota Hilux
Answered
on Feb 03, 2018
How much engine oil do I put in a toyota hilux 2.5 d4d?
HI,the 2,5l engines takes about 5l oil,but i would start to pour about 4l and then topping it up gradually while checking the oil level.Good luck.
Make sure you are using the oil recomended by the manufacturer,and dont forget to change the oil filter and the air filter as well,that sometimes can make a big difference.
11/1/2014 8:56:15 AM •
Toyota Hilux
Answered
on Nov 01, 2014
Car won't start appears flat battery then starts normal
#1 problem:Corrosion at battery terminal connections. Ground,too!#2 problem:Probable bad starter.Diagnostic aid: have a buddy help.Locate starter on engine.have your buddy turn the ignition key to the START position when it just clicks.LEAVE the key in that position while you tap on the starter with a steel rod,re bar,long 3/8 " extension. If the starter cranks the instant the starter is tapped,the brushes inside the starter are burned and the starter should be replaced.The "tap" jars the brushes into good contact and the starter motor turns. "Farm boy" diagnostic works! PS: Thanks for an accurate description of the SYMPTOM. So many people skip the symptoms.When it happens,what happens and when it's hot or cold. A deaf mechanic is useless. Blind ones are great!
4/22/2014 12:15:38 PM •
Toyota Hilux
Answered
on Apr 22, 2014
