Those units are designed to be fan cooled after the bulb shuts off. When the cord was pulled, the unit lost power and without the fan, sat there and cooked. Could be a thermal fuse, could be the bulb.
There is a color wheel that is in those units and there is also a decoder it could be either one. You can check the color wheel to see if it is damaged. THe bad thing is that they are expensive. Especially if it is the decoder.
JustAnswerhttps://www.justanswer.co.uk > electronics > h66cm-n...
Jul 2, 2021 - Question - I NEED MY PASSWORDS RECOVERED OR COMPLEATLY, COMPUTER, BENQ, - . Find the answer to this and other Electronics questions on ...
1 answer · Top answer: Thank you for your question. My name is ***** ***** I look forward to assisting you. I'm ...
https://esupportdownload.benq.com > UserManual
PDF
Download Dual screen driver from BenQ website. 2 Surface Setup. 3 Camera Installation on Projector( please refer to corresponding PointWrite User Manual).
PDF
To link to the Projector Network Display System web page, click Link. 5. Disconnect. To disconnect from the projector(s), click the Disconnect icon.
https://www.benq.com > en-us > education > edtech-blog
1. Use a cable. The simplest, most common way to use Microsoft Office files on your BenQ Board is to connect your laptop using an HDMI or USB-C cable. · 2. Use ...
Sorry I don't really have an answer I had the same issue with a Sanyo I had to keep putting back the old lamp and getting it to start on that one then shut down and swap, eventually it worked, it was a pain. in the end I bought an led projector for the price of a new lamp for the old one
Presuming it is a Benq? Moved Question to Benq from Televisions category.
Lots of references to the section in the manual, but nothing to tell you how to fix it! Seems like it doesn't understand the date being fed to it. Contact Benq Support.
https://www.google.com/search?q=%22Scaler+shutdown+fail%22
Please include 'make model (what it is)', in all questions.
Hi and welcome to fixya.
my name is Yan ready to assist you today.
I'm sorry to hear you're having trouble.
Hopefully, we can get this resolved quickly.
Make sure the power cord is securely connected to the projector and to a working electrical outlet. The projector's buttons may be locked for security. Unlock the buttons or use the remote control to turn on the projector. The power cord may be defective.
