20 Most Recent Lexicon Omega Desktop Computer Recording Studio System Questions & Answers
Cubase studio 5 has deactivated the VST system
In my experience, reasons for seeing errors in VST System Link (VSL) are usually due to the digital signal path (audio and/or data) not being routed properly within the System Link dialog box. If for example, you're using s/pdif between two ASIO 2 compatible audio cards properly (OUT of card #1, to IN of card #2 - then OUT of card #2 back IN of card #1), you also have to set your s/pdif System Link I/O channels in the dialog box to the 'same' channel...If say your options are s/pdif channels 9 & 10 (or whatever they are), you set the I/O's of both computers VSL dialog boxes to either channel 9, or all to channel 10. You of course need to route your digital audio properly within your audio interface! (see your cards documentation on that). You can test if it's routed properly by 'listening' to audio from each computer, from the other...meaning listen at computer 2, from computer 2 & visa-versa. If you hear the audio thhen it should be correct. But in order to 'hear' the audio (besides proper settings in the VSL dialog box) you must 'also' set those digital audio s/pdif channels within Cubase's VST Inputs/connections. But in 'this case', you use both channels 9 & 10 for your Inputs/Outputs. They also say it's best to place your VSL digital audio channels at the top of the Inputs/Outputs list. You do not need to keep the s/pdif channels in the VST Inputs/connections to make System Link work however, that's if you need to 'listen' or if you need to test whether it's routed properly. Getting VST System Link working can seem complicated at 1st, but once you understand, and have it working, you realize it's actually not that hard at all. I recommend taking notes, and writing down what you did to make it work, as you go along the way. That has come in very handy when I need to use it again. Also READ your PDF manual and follow that to the letter!
12/8/2015 1:25:21 PM • Lexicon Omega... • Answered on Dec 08, 2015
Vst system link errors
In my experience, reasons for seeing errors in VST System Link (VSL) are usually due to the digital signal path (audio and/or data) not being routed properly within the System Link dialog box. If for example, you're using s/pdif between two ASIO 2 compatible audio cards properly (OUT of card #1, to IN of card #2 - then OUT of card #2 back IN of card #1), you also have to set your s/pdif System Link I/O channels in the dialog box to the 'same' channel...If say your options are s/pdif channels 9 & 10 (or whatever they are), you set the I/O's of both computers VSL dialog boxes to either channel 9, or all to channel 10. You of course need to route your digital audio properly within your audio interface! (see your cards documentation on that).You can test if it's routed properly by 'listening' to audio from each computer, from the other...meaning listen at computer 2, from computer 2 & visa-versa. If you hear the audio thhen it should be correct. But in order to 'hear' the audio (besides proper settings in the VSL dialog box) you must 'also' set those digital audio s/pdif channels within Cubase's VST Inputs/connections. But in 'this case', you use both channels 9 & 10 for your Inputs/Outputs. They also say it's best to place your VSL digital audio channels at the top of the Inputs/Outputs list.You do not need to keep the s/pdif channels in the VST Inputs/connections to make System Link work however, that's if you need to 'listen' or if you need to test whether it's routed properly.Getting VST System Link working can seem complicated at 1st, but once you understand, and have it working, you realize it's actually not that hard at all. I recommend taking notes, and writing down what you did to make it work, as you go along the way. That has come in very handy when I need to use it again. Also READ your PDF manual and follow that to the letter!
12/8/2015 1:03:22 PM • Lexicon Omega... • Answered on Dec 08, 2015
0answers
Audio inputs
Be the first to answer 11/1/2013 4:16:05 AM • Lexicon Omega... • Posted on Nov 01, 2013Be the first to answer
0answers
Hi there , i have lost my lexicon omega
http://lexiconpro.com/support_assistant.php?region=us
This is a website for Lexicon. This i their support tab and at the bottom is a phone number. I hope this helps you.
3/5/2011 12:57:18 PM • Lexicon Omega... • Answered on Mar 05, 2011
I'm looking for a driver for Linux. Don't
Contact folks at Guitar Center, they sell, handle and repair these daily. They'll give you step by step instructions. (Through their Pro Audio dot)
2/26/2011 12:59:26 PM • Lexicon Omega... • Answered on Feb 26, 2011
Is there a way to reset the Lexicon Omega (power
You can reset your Omega by powering on the unit while holding down the Mic USB button and the Line 3 USB button.
12/2/2010 5:52:57 PM • Lexicon Omega... • Answered on Dec 02, 2010
I have a few issues with this. when i record in to
try this cubase update:
http://www.steinberg.net/index.php?id=880&L=1
10/28/2010 3:04:10 AM • Lexicon Omega... • Answered on Oct 28, 2010
Device: Lexicon Mac USB (lexicon Direct Device)
Send this info to lexicon omega website.They do answer questions for you..They should know what that error means.
3/6/2010 9:15:37 AM • Lexicon Omega... • Answered on Mar 06, 2010
Omega Studio won't record to computer
The omega is like an external sound card. It has to be connected via your computer with a device driver,the software that came with the lexicon. Then you record on a software program such as Cubase.
Go to the guitar center for more help or go to google .com and type in lexicon omega. Lots of sights to look for answers or better yet go to lexicon omega's home site.
3/6/2010 9:12:30 AM • Lexicon Omega... • Answered on Mar 06, 2010
2answers
I would like some help to setup my new omega
What sort of help do you need?
http://www.lexiconpro.com/product.php?id=6#downloads
There are some helpful files here for the omega lexicon pro.
Hope this helps!!
2/23/2010 8:11:27 PM • Lexicon Omega... • Answered on Feb 23, 2010
2answers
Tascam mf p-01 portastudio
hi sounds like a worng channel or no output from something check the tape output's for anything if there is sound but bad or low then the tape is the problem if it's good then check that the cable connection is good (connect it to a reciver) then if all is good till the unit: check that you are listening to the right channel check that your output device is good (headphones,speakers) (connect it to a reciver) good luck
12/15/2009 6:48:42 PM • Lexicon Omega... • Answered on Dec 15, 2009
Computer type
My experience is that it doesn't work well on ANY computer. I would steer clear of the Omega. I have had one and have had nothing but grief.
That being said it "should" work theoretically.
9/16/2009 2:47:37 AM • Lexicon Omega... • Answered on Sep 16, 2009
2answers
LEXICON RECORDING SYSTEM-NOT SURE WHAT'S GOING ON
I think what you are trying to ask is: You've got the hardware (The Mixer Proper) installed, and need the software. The software is called Cubebase LE.
More info here:
http://www.zoom.co.jp/english/products/cubase/cubase.html
Google!
http://www.google.com/search?hl=en&rlz=1G1GGLQ_ENUS276&q=Cubase+LE+download&btnG=Search
3/14/2009 6:23:12 AM • Lexicon Omega... • Answered on Mar 14, 2009
Installing omega lexicon desktop recording studio
Yes it's extremly tempramental, just keep repeating the proces it' will work eventually!
3/10/2008 4:35:23 AM • Lexicon Omega... • Answered on Mar 10, 2008
Cracking noise of Lexicon MC12HD
replace your hdmi cable between tv and preamp...lemme know if it works.
3/24/2014 2:36:46 PM • Lexicon Audio... • Answered on Mar 24, 2014
Lexicon Omega Desktop Computer Recording Studio System Logo
25 questions posted
Top Lexicon Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Lexicon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Lexicon Audio Players & Recorders
Most Popular Question
cubase studio 5 deactivated vst system
  • Audio Players & Recorders
