20 Most Recent
Canon imageRUNNER 400S Copier Questions & Answers
How can I improve the
Hi
If there is text with the photos on the page, set the quality to photo/text mode. If you are copying just photos then set the quality to photo mode.
7/1/2021 5:51:20 AM •
Canon...
Answered
on Jul 01, 2021
Web roller is loose
you will need to take the fuser out and remove the top part of the fuser where the web is.
there is a gear in there that fails to advance the web, it may need to be replaced
11/20/2019 6:43:15 AM •
Canon...
Answered
on Nov 20, 2019
E004 error
clear error or
replace the fixing unit..
11/18/2019 5:31:45 AM •
Canon...
Answered
on Nov 18, 2019
I have canon ir400 machine...
Sir i have recently purchased IR 400 canon photcopier my problem is the
machine is giving error 604as soon the machine is started problem . plz solve my problem
7/22/2019 3:30:37 AM •
Canon...
Answered
on Jul 22, 2019
Changing toner
Hello Glenda
I believe I can help you as I am prepared to send the entire users manual to in a PDF format if this is ok. I specifically found the remove used toner and add new toner section but I believe you may benifit from thr entire manual. Although I am new to this "FIXYA" forum I am a 20 year veteran toner boy(lol) so I am sure I can help. Just respond to "FIXYA" with a favorable comment and let me know how you wish me to respond. I see your E-Mail address and can send it that way which seems the most effective way. Glad to help, happy New Year. P.S. even if ya dont say happy things about my I help I will gladly help, I was just hoping 4 an atta boy from them! :-) Take care.
12/1/2018 11:24:56 AM •
Canon...
Answered
on Dec 01, 2018
405 canon code e604 error ir machine xerox
Check the Image Server Memory or the Image Processor PCB. The recommended Image Sever Memory should be Kingston 32MB, 144 pin EDO Module, 64 Bit, 60 nanoseconds, No Parity
10/12/2018 8:26:42 AM •
Canon...
Answered
on Oct 12, 2018
E805 error in canon ir 400
E805 error code means failure of one of the many fans inside the
copier. If there is not a dash with four numbers after the 805 code on
the display, it is one of two fans - FM1 the transport bed fan or FM9 -
the reversing fan just below the fuser assy. There are several checks
that can be done but a too lengthy to be described. A tech maybe the
best answer depending on your mechanical ability.
9/5/2018 8:30:50 AM •
Canon...
Answered
on Sep 05, 2018
E803
i have ir400 machine but not touch the sharpnees button
6/13/2018 5:12:50 PM •
Canon...
Answered
on Jun 13, 2018
Error e805 ir 400
my cannon ir400 xerox machine is on but no working power supply is full but not run machine
2/22/2018 3:32:55 PM •
Canon...
Answered
on Feb 22, 2018
Canon 405 Problem
when i start copy Error E100 occurs. How do i solve this problem please immediately send me the manual of canon 405 and immediately send me solution of this problem.
1/25/2018 2:06:39 AM •
Canon...
Answered
on Jan 25, 2018
