20 Most Recent
Bogen Communication Bogen Manfrotto 3046 TRIPOD w/ PRO VIDEO HEAD / Cat. No: 3046-3433 Questions & Answers
The tripod legs on my manfrotto 3433 slip. the
Hi toolroom347,
There are different clips on the tripod which allow you to adjust the settings for a firmer grip, you also need to extent the gap between the legs of the tripod for a firmer grip, this will help you to set the optimal settings for your tripod which will be fair enough to carry the weight of your camera.
Also a simple solution to stop this slip problem is to carry a small piece of cloth which has guide good grip or a rubber material and then place your camera on it , this will work excellent for a firmer grip.
This has definitely worked for me.
Hope this helps you as well...:)
8/26/2011 6:55:11 AM •
Bogen...
Answered
on Aug 26, 2011
Fluid head platform is moving before the fluid
Below the head where it attached to the center column is a set of three screws. Back them out a little bit and then tighten the head, then screw those three grub screws back in to lock the head.
4/5/2010 1:38:47 AM •
Bogen...
Answered
on Apr 05, 2010
How do i remove the video head from the tripod
Raise the center column all the way up. Under the head next to the center column are at least 2 or 3 screws. Back them out uing a meduim slotted screw driver. The head should then screw off.
2/28/2010 9:23:51 PM •
Bogen...
Answered
on Feb 28, 2010
Need bottom section for 2 Bogen3218 monopods any
Individual parts (and the parts list) are availble from Bogen-
http://www.bogenimaging.us/Jahia/site/bius/cache/off/pid/14084
You can get the parts list from:
http://www.manfrotto.com/Jahia/spareparts/site/manfrotto/cache/offonce
but the "search" doesn't seem to work when you put in the code (3218), so you may have to scroll thru the 1300 docs til you get to yours- are you sure it's a 3218- they don't show one, but they show a 3216
8/25/2009 10:08:08 AM •
Bogen...
Answered
on Aug 25, 2009
Leg clamp tightening adjustment on a 055 tripod
There should be a nut on the other side of the housing of the tightening lever that you can tighten. Turn the lever to unlock the leg then start with 1/8 th turns of the nut to tighten, then turn the lever to lock the leg. Do this until you get the desired locking.
3/20/2009 6:04:09 PM •
Bogen...
Answered
on Mar 20, 2009
Film won't load on Vectis 300 MinoIta
The clue is in your descrition; Old.
If the mechanism has jammed, due to age or lack of use that causes tarnisg=hing on the contacts, the motor/mechanism will not load.
I would get it serviced at an aurgorised Minolta repair shop.
Contact Minolta for a list of authorised repairers.
3/22/2024 7:04:40 AM •
Photography
Answered
on Mar 22, 2024
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
If your picture frame is not recognizing the 16GB PNY card and displaying a "No Card" message, there could be several reasons for this issue:
- Compatibility: Some picture frames may have limitations on the size or type of memory card they can accept. Ensure that the picture frame is compatible with SDHC or SDXC cards, as these are the types commonly used for higher-capacity cards like 16GB.
- File System: Check if the memory card is formatted in a compatible file system such as FAT32 or exFAT. Some picture frames may not recognize cards formatted in other file systems. You may need to format the card using a compatible file system on your computer before using it in the picture frame.
- Card Reader Slot: Ensure that the memory card is inserted correctly into the card reader slot of the picture frame. Sometimes, improper insertion can prevent the device from detecting the card.
- Card Compatibility: While SDHC and SDXC cards are generally backward-compatible with devices that support SD cards, some older picture frames may have limited compatibility with higher-capacity SD cards. Try using a lower-capacity SD card (e.g., 2GB or 4GB) to see if the picture frame recognizes it.
- Faulty Card or Picture Frame: If none of the above solutions work, there may be an issue with either the memory card or the picture frame itself. Try using the memory card in a different device to check if it's functioning correctly. Similarly, try using a different memory card in the picture frame to see if it's able to recognize it. If the problem persists, there may be a hardware issue with either the card or the picture frame, and you may need to contact the manufacturer for assistance or consider replacing the faulty component.
By following these troubleshooting steps, you should be able to determine the cause of the issue and resolve it accordingly.
3/16/2024 9:30:07 AM •
Photography
Answered
on Mar 16, 2024
Need OptiPix Pro software
I own the OptiPix DPF and here is a pic of the owners manual with directions for the OptPixsetup file.
11/25/2023 1:11:02 AM •
Photography
Answered
on Nov 25, 2023
Driver for target australia film scanner f100
I own the Target AU F100 film scanner and have the original CD. It has a Driver directory on it, which includes DriverInstaller app and 32 and 64 bit subdirectories. It installed recently on my Win 10 64 bit PC and worked ok, despite being Win XP/Vista software vintage 2010.
6/14/2023 3:09:06 AM •
Photography
Answered
on Jun 14, 2023
