20 Most Recent Casio DB360G-9A 30 Pages Telememo Watch Questions & Answers
How to set analogue time
yes very helpful
10/24/2017 9:04:00 PM • Casio DB360G-9A... • Answered on Oct 24, 2017
Can not remember how to install the batteries in a
You really need provide the *FULL* model, as there are a few in the Casio 1737 range.Tip - wIth the back off, sometimes it is best to draw what you see, which can help when reassembling.Removing the battery retaining 'cage' is not easy, until you know how. Under one of its corners, a small tag extends to help hold it in place. You need a magnifying glass to see the tag. Then move the cage into a position that it can removed. A watchmakers small screwdriver helps with this.You will not find these details in the User Manual!Good Luck - Mike
2/22/2016 10:44:28 AM • Casio DB360G-9A... • Answered on Feb 22, 2016
11answers
Casio telememo 30 syncronising analogue and digital time
To set the analog time to match the digital time...
There are 4 buttons: top left=A, top right=B, lower left=C, lower right=D
Get the watch in timekeeping mode (where it shows the digital time or date)
Press C six (6) times
Hold down A until the current digital time begins to flash
Press D repeatedly to advance the analog time, one minute at a time.
If you need to advance the analog time at high speed, HOLD D DOWN.
To return to regular timekeeping mode, press C
Set the digital time so that it matches the analog time, since you can reset the seconds easily.
11/3/2015 9:49:04 PM • Casio DB360G-9A... • Answered on Nov 03, 2015
0answers
0answers
Reset time
Be the first to answer 4/30/2014 3:32:25 AM • Casio DB360G-9A... • Posted on Apr 30, 2014Be the first to answer
0answers
0answers
Set time
Be the first to answer 3/10/2014 3:20:45 AM • Casio DB360G-9A... • Posted on Mar 10, 2014Be the first to answer
0answers
Casio Telememo 30 I need to change my battery
There are plenty of watches around where you can find writing Shortcut battery and AC. Some writings explain how many times you have to shortcut and for how long as well. Make sure you read exactly what it says and do exactly what it says. Shortcut is needed to restore all watch settings and to make all functions work properly. Shortcut must be done right after replacing watch battery, before any settings. Please note - if you are not quick enough with battery replacement, all previous data from watch memory will be lost. Usual max time for battery replacement is 3 minutes. So, when you decide to replace battery, do it as fast as you can, just make sure do not damage the watch in a rush. When the new battery is in place and in right position, get an eyeglass or magnifying glass and carefully examine watch movement all way around. You should find brass/silver coloured contact with letters AC next to it or even on it. This is exact point for shortcut. Take fine pointed tweezers and touch with one pointed end battery's + and with another end AC contact and hold for 3 seconds. If writing in the watch says Shortcut twice, then do it twice for 3 seconds. When shortcut is done, your watch is ready for use and you can set the desired time, date, month and so on.Hope this will help for everyone who want's to save few quid on watch repairer charges.There are plenty of watches around where you can find writing Shortcut battery and AC. Some writings explain how many times you have to shortcut and for how long as well. Make sure you read exactly what it says and do exactly what it says. Shortcut is needed to restore all watch settings and to make all functions work properly. Shortcut must be done right after replacing watch battery, before any settings. Please note - if you are not quick enough with battery replacement, all previous data from watch memory will be lost. Usual max time for battery replacement is 3 minutes. So, when you decide to replace battery, do it as fast as you can, just make sure do not damage the watch in a rush. When the new battery is in place and in right position, get an eyeglass or magnifying glass and carefully examine watch movement all way around. You should find brass/silver coloured contact with letters AC next to it or even on it. This is exact point for shortcut. Take fine pointed tweezers and touch with one pointed end battery's + and with another end AC contact and hold for 3 seconds. If writing in the watch says Shortcut twice, then do it twice for 3 seconds. When shortcut is done, your watch is ready for use and you can set the desired time, date, month and so on.Hope this will help for everyone who want's to save few quid on watch repairer charges..And keep up the good work you are doing for the country...
9/30/2013 4:48:41 PM • Casio DB360G-9A... • Answered on Sep 30, 2013
0answers
How to set casio telememom 30 date
10/17/2012 4:47:57 PM • Casio DB360G-9A... • Answered on Oct 17, 2012
Casio watch no longer beeps.
Try getting instructions from Casio.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Click on "search" and the download your instructions.
If you can't find anything useful, try their technical support.
8/4/2012 12:15:30 PM • Casio DB360G-9A... • Answered on Aug 04, 2012
Casio DB360G-9A 30 Pages Telememo Watch Logo
76 questions posted
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Casio Watches
  • Casio Watches
Most Popular Question
dont know set watch
  • Watches
