20 Most Recent
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Questions & Answers
04TA0691 power supply
Hi
I have a .pdf of the diagram - can you let me know your email so I can send it - it's too big to attach.
Glyn
Removing STK-392-110 chip
Hi, they overheated and are really stuck to the heatsink compound you will have to use a flat blade screwdriver and a hammer and tap them until they break loose, be SURE to remove the old white heatsink compound before you apply the new compound to the new stk`s, you did purchase a tube of heatsink compound for the new stk`s right? No compound = cooked stk`s in 6 months, good luck, video-tek
Just bought and installed convergence board and green is sweaped to one side in the middle
It sounds that the convergence adjustments should be re-touched.
If you wish to get more details, check this site linked
below. Pull up older posts there. Check
the site with patience, as it has over 2350 posts now. All are related to electronic equipment
repair help. If you search the site in
Timeslide option, which can be selected from the drop down list at the top left
of the display window, it will be easy to locate the related post. You can also do a search by type in the
brand name to your device into its search box at the top right of display
window.http://electronicshelponline.blogspot.com/
Picture looks double
Most likely the two stk-392-110 convergence chips are bad and need replacing, several sites sell kits for this.
Jvc tv has double exposure and curve
Convergence is most likely for this model------that circuit in this set is right at front behind grill below the screen.If you can solder it is a do it yourself type repair with parts under 30 dollars (most shops get 250 average parts and labor) and I can tell you how to get that board out and what is needed.
Here is the board removed from a set.
