20 Most Recent
JVC HD-61Z575 61" Rear Projection HDTV-Ready Television Questions & Answers
Lights blinking so purchased new bulb, didn't fix
Most times client forgets to re install the access door to the lamp after replacement, but if you think the fan is bad try using compressed air and blow it out 1st with the set off. Recycle the ac. ( unplug set then replug it back in)
JVC TV lamp indicator light blinking new lamp
if you purcased a LTI lamp then the possibilty of a bad lamp may be the case. LTI lamps are cheap and are poorly manufactured. if it is a JVC lamp then you may have further problems such as lamp balast, or thermal sensor. clean the fans and filtersfor better air flow. keeping the lanp cool is important for the life of the lamp.
Tvand sound comes on but no picture
It is hard to say what the problem could be. A lot of boards on this unit can cause the same condition. Lets start out simple. Can you get the menu to pull up? If you can then check your connections at your inputs and at the components that you have hooked up to the TV. If you can't bring up the menu, then I would suggest having a servicer look at it. You could have a bad tuner causing this, a bad digital board, bad analog board or even a bad light engine. To many variables.
Blue colors are bright green
This model did have problems with : missing color (red,green or blue) and other issues like inverted picture-----it may need the main cpu reprogrammed which is done with a jig and two sd cards loaded into the set that way.
Turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
How to replace busted focus tube
They must have meant picture tube, a rear projection set has three picture tubes. One red, green and blue. One tube cost probably $150 - $250 and are not that hard to change but doing the necessary convergence adjustments can be difficult especially if you have not done them before. One thing that always makes it a difficult decision is when you put one new tube in will the other two still be in good enough condition to get a good color balance.
The power butto lihgt blinking bud no turn on
blinking light indicates that some thing is wrong inside the tv circuitary. may be any IC of any other component is short & not letting the power supply working. if you are a technical expert of tv you can cold test the power supplies for short circuit. or you can call a tv repair expert.
Replaced lamp in my HD
The old lamp was in there before the fan work?U replaced the lamp u put the door back on did u make sure the safety latch is off and tightly closed with the the lamp door.The continue blinking LED light does it make alot of clicking noises too.Yes,then the Ballast board it is dead too.The Ballast board only job are to help the projection lamp to ignite to work.
