20 Most Recent JVC HD-61Z886 61" Rear Projection HDTV Questions & Answers
Hdmi cable not working
You have a bad main board it sounds like.
1/6/2018 9:53:56 PM • JVC HD-61Z886... • Answered on Jan 06, 2018
2answers
I rewired the power cord to my JVC Projection TV, because the old one had been chewed up. Now, when I try to plug it into electrical outlet, it sparks and blows a breaker on my house breaker box?
The wires are shorted together somewhere! Or you switched ground with hot or neutral! Are you trying to burn down your house? Even if you manage to get it working, it still could be a fire hazard because it isn't done correctly! Wrong kind of crimp or a bad solder job can create a fire! PLEASE get someone that knows electrical or electronics to fix it! Most of the people I know that have the background can fix it correctly in about 10-15 minutes.
7/28/2016 4:08:13 PM • JVC HD-61Z886... • Answered on Jul 28, 2016
0answers
I have a JVC 61"
your picture tube may be blown?
3/14/2013 12:48:05 PM • JVC HD-61Z886... • Answered on Mar 14, 2013
JVC HD-61Z886 61 picture is dark. Is this fixable.
Could be dust in your light engine or build up on your mirrors.
6/22/2012 7:53:31 PM • JVC HD-61Z886... • Answered on Jun 22, 2012
HDMI ports not working on JVC TV
Unplug (if you have not tried it) the set for a while (do the same to a box if using one) and plug both back up after a while and see if a reboot on both will restore operation.Highly unlikely for both to fail at same time.
4/1/2012 5:14:28 PM • JVC HD-61Z886... • Answered on Apr 01, 2012
I have a JVC 61"
Hi clodfelter00,
Dim picture was a symptoms of lamp peak burning life and needs a replacement. Click this LINK to place your order online.
HOW TO REPLACE THE LAMP UNIT
(1) Turn off the TV power. (2) Disconnect the power cord from the AC outlet. (3) Loosen 1 screw from the rear side, then take out the the left speaker panel. (4) Loosen 1 screw then take out the lamp cover. (5) Loosen 2 screws then take out the lamp unit. (6) Install the new lamp unit. (7) Re-install the lamp cover. (8) Re-install the left speaker panel. (9) Re-install the screw to the rear panel.
NOTE: After installing the new lamp unit, do not forget to reset the lamp timer.
HOW TO RESET THE LAMP TIMER
(1) Press the [MENU] key to select CLOCK / TIMERS. (2) Select the with UP/DOWN key. (3) Enter the mode the message will appears. (4) Press the [OK] key while the above message appears on the screen. (5) Turn off the power, then turn on the power. (6) The lamp timer has now been reset.
Watch this VIDEO for more info.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
5/26/2011 2:13:29 AM • JVC HD-61Z886... • Answered on May 26, 2011
Just change the bulb few
Hi, did you make sure it was the right lamp the reason is that theres two types of lamp one that shoots the light wider and another that concentrates on the center.Also check the ballast the main power of the bulb it comes to happen that when u put in a new bulb the ballast is not able to provide enough power to light up the whole screen.
4/19/2011 12:34:29 AM • JVC HD-61Z886... • Answered on Apr 19, 2011
JVC HD-61Z886 61" Rear Projection HDTV Logo
58 questions posted
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
rewired power cord jvc projection tv
  • Televison & Video
