20 Most Recent
JVC HD-52G886 52" Rear Projection HDTV Questions & Answers
Power light blinks but no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
The blue and red light is blinking on my JVC dlp t...
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Black spots on philips tv
Sounds like your light engine may be dirty or just faulty. You might try taking a dry rag and cleaning the lens on the light engine. If you decide to replace it or send it someplace for repair the part number is TS-COP9A-SAA
My jvs tv the sound works but no picture someone
This is a dlp or digital light projection tv. This set uses a bulb. First check the bulb. The bulb can ussally be removed from the set from the back with a screwdriver. do not touch the bulb front. this set does not have a flyback. 90 percent of the time the bulb will shatter when bad.
Chromecast is not working with jvc hd52g886
Don,
The HDMI is best..but you need the standard HDMI cable. BUT this JVC is in the new Noah movie? Seriously, it wont handle Roku. The digital in function is strictly 480 p.
I think you will have to upgrade to a newer tv for this source
