20 Most Recent
JVC AV-32FA44 32" TV Questions & Answers
We have a JVC AV-32FA44
There seems to be issues with the soldering on it getting old and loose, also there are some common parts that burn out or go bad over time. I am not sure if you want to spend the money or are going to be able to find someone to fix it.
2003 JVC AV-32FA44 dark screen
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Turned on my JVC AV-31FA44 32
Check its power regulator section and Line Output Transformer. The work is a skilled one, and only an expereinced service technician can go for ward. You must have its repair book with you too.
Jvc av-32fa44 television
My JVC AV-32FA44 wont turn on. the on timer light blinks. When i unplug it and plug it back in i get beeping (i stoped counting at 50 beeps) then it stops and the light just blinks.
TV made a loud pop
hi,
sounds like a popped power capacitor, its going to have to go to the shop most likely around 100.00 repair. taking the back off yearly and airdusting them helps, especially if you have a smoker in the house. caution high voltage present even when off, the heavy single red wire going to the tube is high voltage be careful.
J
Dark Picture
Hi there!
The knobs you refer to, are those perhaps the knobs on the board or knobs on the flyback transformer? None of these knobs should be turned. They are preset to the factory standard and if a fault occurs the fault should be addressed, not adjustments to pots. I would suggest checking all the caps in the power supply, Line stage and video section. It may also be the video processor(in the area of the tuner section). Check for caps which are rounded at the top. This is common for dark picture. Please note: There is on average about 15000V running through a TV when switched on, please be careful and unplug when changing components or refer to a repair technician. Good Luck, Jus004
Lost TV picture
Hi there!
I noticed that you were having some difficulty with ratings or something. But I also don't see a solution to your problem. The problem you have is not common and could be anything from electronic to software fault in the EEprom. I would have the transmitting on the remote tested first. It can be done without the TV at a repair technician that has the relevant tools. Note: Don't know who you communicated with, but this service is free as far as we are able to help people like yourself with basic information. Like myself and all the others we do not get paid to sit on this site and certainly don't expect ratings. We monitor our ratings to see how many people we could help with their problems and for me personally, is enough. If you have any question please mail Fixya direct. Good Luck with the problem, JUS004
No picture, No sound
Hi there!
If the set is dead after the popping sound, then it has probably blown a component due to high voltage. Everything inside a tv starts with the power supply. Nothing will work unless the power supply is 100%. I don't know what your rates for repairs are in general, but the price sounds good. The final decision is yours to repair or replace. Good Luck, JUS004
Thick plastic film covering glass screen got deeply scratched while moving
Hi there!
I would simply replace the plastic sheeting. Will certainly be cheaper than replacing a tube. Glass tvs don't normally come with this plastic so leave it off if you can remove it. There is a type of spray on the market for this purpose, just don't know if available in your country. Please note: It is dangerous to use a tv which had been scratched beyond 1.5mm, The glass may become unstable and implode if bumped by accident. Good Luck,JUS004
JVC AV-32FA44 32" - No Picture, but sound OK
You could have a power supply problem as parts do go bad. Why your set faile is a mystery.. Of course if your not a technician, a TV set is NO place to be experimenting with. It only about a year old you say But get the papers on this set if you can find them and make sure as there is a 12 month warranty on this model. You should contact JVC At 1-800-252-5722 or online at http://www.jvc.com/support/. Good Luck
TV turn off itself and won't turn on
Sounds almost like you have a voltage missing on the power supply board. if its a missing voltage a service manual and a multi meter should help ya find whats missing But a shop repair on a set like this could cost a bit as anything over 27" is a little costoly to fix these days. Only way to see is call and say to your self How old is the set? is it the set you really like do you wanna spend 150 to 225 to repair? it up to you. Good Luck
JVC 43" (109cm) HD Ready Plasma TV PD43N30A. Chunghop universal remote codes for JVC pd43n30a
Question edited for a lot more clarity, plus
Chunghop not chungCHOP :>D
JVC: 089, 161, 909
CHUNGHOP Universal Remote Control Codes
codesforuniversalremotes.com
https://codesforuniversalremotes.com > chunghop-univer...
Jul 25, 2019 -
CHUNGHOP Universal Remote Control Codes ; Aiwa: 009, 057, 058 ; Samsung: 618, 619, 620, 621 ; Philips: 013, 023, 024 ; Hisense: 676, 677, 707, 898
My JVC TV has an onscreen remote that doesn't let us use the actual remote what do I do to gat it out?
Hello! If your JVC TV is displaying an onscreen remote and you're unable to use the actual remote, you can try the following steps to resolve the issue:
- Power cycle the TV: Turn off the TV and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This can often reset any temporary issues and restore the functionality of the actual remote.
- Replace the remote batteries: Check the batteries in your remote control and make sure they have enough power. If the batteries are low, replace them with fresh ones and try using the remote again.
- Check the remote control sensor: Ensure that there are no obstructions between the remote control and the TV's remote control sensor. Clean the remote control sensor on the TV with a soft, lint-free cloth to remove any dust or debris that may be interfering with the signal reception.
- Reset the TV to factory settings: If the issue persists, you can try resetting the TV to its factory settings. Keep in mind that this will erase any personalized settings and restore the TV to its original configuration. Refer to the user manual or the manufacturer's website for instructions on how to perform a factory reset on your specific JVC TV model.
- Contact JVC customer support: If none of the above steps resolve the issue, it's recommended to reach out to JVC customer support for further assistance. They will have access to more specific troubleshooting steps and can guide you through the process of resolving the issue with the onscreen remote.
Keep in mind that the exact steps and options may vary depending on your specific JVC TV model. Refer to the user manual or contact JVC customer support for model-specific guidance.
