20 Most Recent
SYMA Toys industrial 30" RC SYMA Century Boat Radio Remote Control RC Racing Yacht with Display Stand Questions & Answers
SYMA RC CENTURY BOAT DOESN'T WORK OUTSIDE WATER
Actually the Syma Brand Boats are designed to not to work out of water. It is a safety feature. You can bypass that if you like. You remove each wire that is soldered to each propeller shaft and twist them together.
2/17/2015 1:22:14 PM •
SYMA Toys...
Answered
on Feb 17, 2015
Engines might run for a
The boat has an issue that is for safety only allowing it to work in water, this can cause sputtering. You can try to connect a copper wire between the two copper drive shafts. The range on this boat is not great so that may be part of it.
4/10/2014 5:10:59 PM •
SYMA Toys...
Answered
on Apr 10, 2014
SO33G charger over heat ,
It is no use to buy a new charger if the problem is a short. Indications are that it is. When the batteries are in need of replacement and wont charge up, overheating of the charger will also occur.
1/3/2018 11:10:24 AM •
SYMA Toys...
Answered
on Jan 03, 2018
Syma so33g lower blades do not rotate
wrong!!! if the bottom set of blades aren't turning its because the drive gear for that shaft is loose and is spinning on the shaft instead of spinning the shaft itself. try tightening the screws but make sure the screws are lined up with the holes in the shaft so they seat otherwise your going to strip the plastic gears threads. if that doesnt work then you will have to replace the gear and shaft. its a cheap part and readily available. only problem is youll have to take apart almost the entire heli to get the old one out n the new one in. the gear comes pre-mounted on the shaft. Buy 2 or 3 of them right away as you will have to replace it just about every time your heli tips over while the blades are turning. the screws only go into the shaft about a 16th of an inch and is easily stripped out
12/26/2012 8:25:07 PM •
SYMA Toys...
Answered
on Dec 26, 2012
