20 Most Recent
LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Questions & Answers
Tv shuts itself off
The power supply may be going on to protection mode. This is usualy because one of the scan amplifiers may have failed, or something is taking too much current and forcing the power supply to shut down.
Jerry G.
Keeps turning off onto standby after 15seconds
The power supply protection is sensing a fault. Can be a problem on one of the boards or the power supply itself. The service rep will test by trying the boards with new ones; one at a time until the faulty one is located. He may start with the power supply board first. Once found he will leave the new board installed. Most of the time these boards are not serviceable at the component level. They use SMD high density design with multi layer boards.
Take care servicing these sets is fairly expensive. If the set is out of warranty it's a gamble if something else will fail shortly after.
LG RU-52SZ51D problem turning on
I have the same problem as Shawn. I'm hoping after about a year this post may pop back up and get a response from someone who could help.
Thanks.
Lamp rest light
Press and hold the Mute button on the remote and at the same time press the Enter button on the TV until the Reset menu appears. Press Center button on remote to clear hrs. Your done!
TV doesn't turn on
I bought a LG 39" flat screen 6 months ago. TV has been working great until this morning. Power comes on for about 5 seconds and then cuts off. Have checked all connections and have unplugged from wall to reset, NOTHING!! And a brand new TV!! Any help would be great!
How to replace lamp and reset timer
To reset on the LG MODEL RT-44SZ60DB:
Press OK button on TV and MUTE on control > operation is displayed on screen
press ok to reset
No need for LG to reset this lamp.
