20 Most Recent
LG RU-44SZ61D 44" TV Questions & Answers
Sony wega KV-27FS12, light is flashing seems to be
HiIt seems you tv set has an overload in the output supply line which may be caused by a shorted rectifier diode or a shorted horizontal output transistor and associated circuit. The set should be serviced.Sully
We have a brand new LG TV with a built in DVD
Hi:
The only way to diagnose this problem is to take the DVD out and inspect the take up rollers designed to take and eject the disc. If you hear sound when try to eject you may have a bad belt or the take up rollers are oxcided causing slipage during ejecting.
Screen slow to come on
Weak capacitors are a very common thing. I would suspect that is your problem. It could be in the powersupply or Signal Board or in the inverters. Check with a tech!
Replaced lamp in lg ru-44sz61d dlp picture blue
This TV has no guns. It has a lamp and a color wheel.
Owner reported model number as: lg ru-44sz61d dlp. Pay particular attention to the "dlp" part.
I do not know what is causing the issue unfortunately.
Lg 42 inch projection tv has green light and orange light
It is a possibility, if the indicator lights are on it definitely means something is wrong in the light engine system, it could be your lamp, ballast, color wheel or dmd board, when it comes to LGs it's most probable that your lamp might go out. You can replaced it to see if it fixes your problem, if it doesn't, there's a chance it might be yoru ballast.
ACCESS TO BULB
Looking at the television, on the lower right hand side is the ventilation opening. Remove the screws and then remove the cover. Inside the opening is the light bulb holding bracket that has a handle on it. Disconect the power wires (2) going to the bulb, remove the 3 screws holding the metal cover over the bulb and pull it out of opening. Then remove the screws holding the light bulb in place. Very simple and easy to replace.
Sony trinitron kv-36fs320
The blinking should be in a pattern. When the set shutsdown because of a fault, the standby light will blink a code. This code should be a number of blinks followed by a 2-3 second pause then the code again. Please post that count as that will indicate the fault that was detected. Armed with that information, we should be able to provide you with an explanation of what is wrong and possible solutions for fix it.
Thanks,
Dan
Is my lamp out on my LG?
Most likely you can have 1 or 2 problems.
1! the light is busted and you will have to replace that. You might also need to check your cooler fan bearing as you indicate it makes noise.
Please open following link( you need acrobat reader)
this is the service manual for your TV
ru-44sz61d
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
