20 Most Recent
Conair Chrome Double Sided Lighted Makeup Mirror Questions & Answers
How do you get the mirror apart to change the
Here are the instructions, basically you remove the screws on each side and then on side will lift off. I used a flat head screw driver to work around seem until it lifted off. Hope this helps.
http://www.conair.com/instruction_booklets/06PM8043%20BE18NX.pdf
How do I open the housing of Conair Makeup mirror
The two sides do come apart but tend to stick. Pull the magnifying mirror apart from the mirror that is attached to the stand. You may need to budge it a little on one side and then the other to get it to come free, but it will.
Can the mirror be replaced on an a BE103 ?
My mirror is not like the picture shown. I have a True Reflections mirror by Conair with two sides and changes shades for what kind of light I want, I just wanted to know what are the two whit things that fell out of the mirror when I took it apart to change the bulb? There are two squares that appear to be batteries of some kind and the two things that fell out were near them. but I have no idea where they were.exactly or it they are necessary. Can anybody help me figure that out? Thanks! J. Burke
How do you use a
The settings 1-10 are for wet and easy-to straighten hair. Like hair that is a little thinner or almost straight.
The settings 11-17 are for damp hair that is about average thickness.
The settings 18-23 are for hair that is thick or wavy.
Lastly, the settings 24-30 are for dry hair that is harder to straighten.
So, the higher up you go, the higher the difficulty the hair is.
Hope this helps! :]
