20 Most Recent
W90-Ru-B Rapide Ultra Upright Carpet And Upholstery Washer Questions & Answers
Not drawing water into the dirt container
You can get guide from many sites.. i know few
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
Brush not working belt is ok
This in the automotive section and not the household appliance section....BUT.. double check to see if you have the right belt for this particular model. If all else fails, take it to a vacuum cleaner dealer and they should be glad to help you, may be as easy as mis-installed parts.
Fitting hose
Do you mean store hose or fit for use, if its fit for use then the rapide has a small flap at the front (normally has VAX logo on it) lift gently and push hose onto it and turn to lock. if its the spray hose (smaller hand held spray nozzle) then it connects a bit closer to the washer main case on a small normally orange valve which again pushes and locks. Hover has to be in upright position for hose to suck.
Just had delivery of Vax rapdide ultra carpet washer. Trying to assemble but cannot see where the hose fits into the base?
Hi, I also have a rapid, the hose pushes and turns into the clear front were it collects the old water. There is a sprung small clear plastic flap that you gently lift up and the hose pushes gently into then turns about 90 degrees to lock in place. Its located just under the orange carry handle with VAX engraved on it. the small orange valve at the top of this is for dispersing cleaning fluid from the small hand tool that sits on the handle which again pushes on and turns to lock. But be careful when taking off as it will still have a small amount of pressure in it and will squirt a little.
The water and solution leaks out over the left side wheel and doesn't feed to the sprayer as it should
so either the pipe is cracked or there is a missing gasket. Assuming this device was fully assembled when you received it I would check for any cracks or damage inside the containers or at the point of leakage. The best advice I would give for this is to return it if under warranty or send it to the manufacturer for servicing. If you're a serious DIYer you could disassemble it, the damage will be apparent from there.
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
What is hashtag
hash·tag
noun
(on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
