20 Most Recent
Acer Aspire 5810T-8060 Notebook Questions & Answers
WHIRRLING NOISE
take the side of the case off and carefully stick your finger into the center of each fan to slow it down, if the noise stops, it's time to replace that fan, which is easy enough.
Where can i find the capacitor on my acer aspire labtop
Laptop* It sits in your lap. If you open the laptop you will discover dozens and dozens of electrolytic capacitors. All electronic equipment have them. They are the most common cause of failure. They have an electrolyte in them just like a battery does. Over time this electrolyte dries up. Every 4 or 8 years it is good to replace them. Bad capacitors will be bulging. The tops have a cross on them to allow them to bulge if it needs to so that they don't make a pop like fireworks..
Acer 5810Tpowering up goes to configuring updates
Did you power off during updates, or un intented shutdown happened during updates.Any noise coming from laptop like click click, something slipping again and again.You should run repair as well as disk check to fix and repair entries.
Black screen
It seems that your OS has registry problem.- Start PC in safe mode, normally Pressing F8 key when windows starts up.( Google it)- In Safe Mode create a new user, with administrator privileges and protect it with password.- Remove unwanted software's & programs.- Empty the Recycle Bin.- Download reliable program Reginout to fix OS registry properly.- Restart your PC normally and log on to the new account created.If you don't want to perform these steps, then simply Re-install the Windows.Now its up to you :-) Tc
When I turn on my lab top the windows boot manager comes up
First - re-seat the hard
disk and reboot the computer. If the computer does not boot up then reboot and
go into the BIOS configuration to see if the BIOS detects the hard drive. If it
doesn't detect the hard drive then it could be faulty.
Then the hard drive needs
to be replaced in the computer/laptop, Windows installed and the computer or
laptop's device drivers plus your programs etc. to get a functioning
computer/laptop again.
ACER 5810T LAPTOP BATTERY NOT CHARGE IT SHOW THE MESSAGE "PLUGGED IN ,NOT CHARGING"
If your laptop computer runs normally on your
acer 5810t charger, but the battery won't charge, please try the following troubleshooting steps:1) Remove the battery from the system.2) Look at the connectors in the bay and on the battery for signs of physical damage.3) Check the battery charge by pressing the status button or image on the battery near the LED's. Note: The lights indicate the current amount of charge on the battery. If all the LED's come on when you press on the butto, the battery is fully charged. If fewer lights are lit, then the battery is partially charged. If any lights flashm or blinkm there could be a problem with the battery.4) Reinsert the battery; puch until it locks into place and the latch snaps back to the locked position.
LCD
I would say you have more problen than vertical lines. You may have Graphic adapter issues, Have you damaged the machine, drop, bump, jarred..etc.? Have you done any updates, ugrades to software, hardware?
Screen
Where is it? In the rear of the monitor, a ribbon cable, and the bottom under the bezel.
Laptop lost battery back-up suddenly.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
A disc error has occured aspire 5810T
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Cannot open wifi
Why not? What type of message are you getting?Have you turned the wireless switch on?Look on both sides and in front of the laptop for the wireless switch.
How do i get into bios
The function key to get into the BIOS is displayed briefly when the laptop starts to boot up.This maybe F1 or F2 or F10. press one of these keys several times as the computer boots up.
HD 4300 driver
You maybe able to get the video driver from the Acer WEB site.Download the device drivers from the Acer WEB site. Makesure you select the model of your laptop the drivers you that require thatmatches the Windows version that is installed on your laptop. Use this link toget to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
