20 Most Recent
Nakamichi CMS-5 CD Shelf System Questions & Answers
I have Nakamichi CMS-5 and cassette deck DR-5. How i configure it to connect with Harman Kardon BDS 277. In CMS-5 there are 4 Jacks that read Processor, What is the purpose of those jacks. Not a singl
There's not a lot of info on the web about the specs and sockets on a Nak CMS-5 or the RE-5 reveiver that's part of the system. So some of this is based on the tiny fragment of information you provided.
The HK BDS277 has no outputs, only inputs. So however you decide to connect, the only way that things will work is if sound signals come from the Nak and go to the HK so that the sound comes from the HK speakers.
If the Nak has processor sockets as you have half suggested, then they act as a break point between the NAK pre-amp which does source selection and the Nak power amp that provides the muscle to drive the Nak speakers. Disconnecting the links from Processor Out/Processor In with interrupt the signal flow. You'll then be able to connect Nak Processor Out to one of the line inputs on the HK.
Any sources already connected to the Nak will then have their signals routed to the HK. The Nak speakers will be silent.
I hope this helps you.
How to connect a Nakamichi CMS-5 Compact Music System with Harman Kardon BDS 277
I hope this helps.
How to switch off alarm clock on Nakamichi NM-CR-C90
To switch off the alarm on the Nakamichi NM-CR-C90, you can follow these steps:
Locate the "Alarm" button on the top panel of the device.
Press and hold the "Alarm" button for a few seconds until the alarm time display begins to flash.
While the display is flashing, press the "Alarm" button again to turn off the alarm.
The alarm time display should stop flashing and return to the current time.
If the above steps do not work, consult the user manual for further instructions or contact the manufacturer's customer support for assistance.
Nakamichi RE-5, CD-5, MD-5 connections? I've lost
The system control is essentially a link between units.
This is required for the remote to access all the units as the re receiver is housed in the RE-5 unit and relays the signals between the units via 3.5 inch mono jack, generally a short black cable to interlink the units.The RE-5 have 1 and add on units have 2.
Nakamichi 680ZX deck: turning speed indicator to half speed does nothing
El deck Nakamichi 680ZX tiene la capacidad de grabar tanto a la velocidad est?ndar de 4,76 cm/s como a la velocidad media de 2,4 cm/s. La grabaci?n a la velocidad m?s baja permite grabar frecuencias m?s altas de hasta 15 kHz, que es m?s alto de lo que se puede lograr con la grabaci?n a velocidad est?ndar. Adem?s, el 680ZX cuenta con una funci?n de memoria de m?sica de acceso aleatorio (RAMM) que permite la b?squeda de pistas, as? como la funcionalidad de entrada y revisi?n. Tambi?n tiene un sistema de calibraci?n de nivel manual y un sistema de alineaci?n autom?tica de azimut para garantizar un registro preciso.
It seems that my CDC3A
it sounds like the laser lens is missing, undo the 4 screws and flip the laser assembly over to check if lens is on, these unit have a common problem with the lens falling out. If lens is out and you find the lens it can be glue back in place, Use white general purpose glue NOT crazy glue as it will cloud up the lens.Note if you remove the lens assembly ribbon cable you will need to short the pin on the cable to prevent static charge destroying the laser, this must be done before removing ribbon cable, once you plug ribbon cable back in remove the short on the ribbon cable
Nakamichi DR 10 does not eject. I loaded a
The DR1o might have a Sankyo transport and they have sense fingers that become tarnished. This needs to be serviced to make the deck work. It is possible that the deck is still in play mode which blocks the eject from taking place. Unplug the unit and open it up and rotate the worm gear with a finger and the door will eventually open up but do not force things as understand the size of motor in the unit that normally turns the worm gear.
I have a Nakamichi 700
Hi,I would suggest you to first trying unplugging/ switching off your device for 5 minutes. This restores and refreshes the device. Go for it
Let me know if this works, if it doesn’t then I’ll provide some other alternative solution.
Thanks
