20 Most Recent Peavey XR 1220 Powered Mixer Mixer Powered Questions & Answers
Peavey xr 1220 monitor 1 and 2 fade in and out
4/17/2023 2:39:19 PM • Peavey XR 1220... • Answered on Apr 17, 2023
On my peavey xr1220, when I turn on the power switch the board does not power up. What could be the problem?
Probably a fuse ? I have been servicing a lot of Peavey equipment lately and they have some poor circuit designs, a lot of internal un accessible fuses, I might be able to get more info ?
6/17/2016 4:19:12 AM • Peavey XR 1220... • Answered on Jun 17, 2016
THe monitor channels are not getting a signal from any of the channeles other than line in sterio on channel 20
This will not be user serviceable. I suggest taking it to a Peavey authorized service center.
4/19/2016 1:27:36 AM • Peavey XR 1220... • Answered on Apr 19, 2016
Connect a Tascam cd-rw900sl recorder to my peavey xr1220 mixer
Call Peavey Suppo and Tascam Support to get the right answer. Peavey com
4/24/2015 1:02:45 PM • Peavey XR 1220... • Answered on Apr 24, 2015
What amp setting do you use when you have two passive monitors 1 ea on amp 1 and 1 ea on amp 2?
You have two monitor outputs, each controlled by a fader. Plug the amp(s) you will be using to power the monitors into these, connect the monitor speakers to the amp(s) and you're set up and ready
2/22/2015 11:50:12 AM • Peavey XR 1220... • Answered on Feb 22, 2015
I want to record using Tascam with my peavey xr1220 mixer
What Tascam recorder are you using? If you are multitracking you will be unlikely to be able to use this mixer. Otherwise get a phono lead to fit the tape out and suitable connections for the Tascam recorder at the other end. This will allow you to record the main mix but unless you are a solo act or putting everything through the PA this will probably be pretty useless to you.
2/22/2015 11:46:05 AM • Peavey XR 1220... • Answered on Feb 22, 2015
2answers
Peavey XR 122D powered mixer developing hum noise dispite pressing the noise filter. anything more to be worth doing?
Hello, I need a bit more information but from what i can tell it's about the power supply capacitors issue, as this devices are known to develop such kind of humming annoying noise when they go under the specified value, let me know further, Regards.
1/13/2015 3:04:33 AM • Peavey XR 1220... • Answered on Jan 13, 2015
Connecting JBLeon g2 powered speakers
balance left right outs to balanced inputs
9/20/2014 5:00:31 AM • Peavey XR 1220... • Answered on Sep 20, 2014
Sound cuts out
check the free air circulation in the power amp module, also check your speaker's impedance, let me know further, sorry for the late answer.
11/7/2013 2:07:14 AM • Peavey XR 1220... • Answered on Nov 07, 2013
I have a xr 1220.
The48 volt supply is a simple rectifier/filter from the power transformer. The schematics don't even show the switch anyplace that one can find it. It appears they don't even regulate the 48 volts... Some Peavey switches are just in a hole that you have to poke something into with an alternate action button. They use these on some equipment for instance for selecting a powered mixer into L/R or Main/monitor setup. Push in with a match stick... From the manual it lloks like this is supposed to be a tiny square button... these are EASILY broken off but usually you can still actuate the switch with a little stick.
9/13/2011 3:08:45 AM • Peavey XR 1220... • Answered on Sep 13, 2011
I have just received my
  • Hi, I can help. If your country does not support 110V @ 60 cycles or (RPM) Revolutions Per Minutes then your Peavey will not function at all.
  • Depending on your country you would need to get a step up or step down transformer which will increase or decrease the voltage and cycles to effectively run your Peavey.
  • This website list many countries outlet Voltage as well as the corresponding Hz or (Cycles Per Minute AKA revolutions Per Minute) http://electricaloutlet.org/
  • When you find your county look to the right and you will see the voltage and Hz requirements. Based on that you can tell if you need a step up or step down transformer. HINT (It will more than likely be a Step Up Transformer.)
  • As you go further to the right on that page you will see the name of the style of plug your country uses also.
  • Then all you need to do is get a Step Up Transformer that plugs into your socket that has a corresponding standard U.S.A. 110 Volt outlet on it to plug your Peavey into into.
  • These are available all over the internet.
  • If you have any comments please feel free to ask.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
8/20/2011 5:24:32 AM • Peavey XR 1220... • Answered on Aug 20, 2011
I have 110v XR 1220
There are dozens of transistors in the unit... we can't guess which you might be refering to. The power supply of the 1200 series mixers have fuse before each part of the supply for the preamp sections.
7/14/2011 6:40:57 AM • Peavey XR 1220... • Answered on Jul 14, 2011
0answers
I have a peavey 1220
Hi. The mixer puts out a full range mix, the solution is in your speaker setup.
Many subs have a built in crossover that splits the signal for the tops. Check your sub specs or manual. If your subs have this, run your output signal to them first and then link them to the tops from the special daisychain socket.
If they don't have one, you can install a passive crossover to your subs or buy an external crossover unit.
The last (and not very good) option is to fake a crossover with the desk's stereo EQ. Connect the subs to the left or right channel and the tops to the other and use the EQ to remove the bass from the tops and vice versa, pan everything dead center. Obviously this sacrifices your stereo sound and isn't brilliant.
6/29/2011 9:18:24 AM • Peavey XR 1220... • Answered on Jun 29, 2011
I have the Peavey PV14 mixer, and suddenly the effects will not work. It is not a new board but I have always taken really good care of it! Help!
It sounds like there might be an issue with your audio equipment or settings. Double-check the connections, ensure proper device selection, and verify if your equipment is functioning correctly. If the problem persists, consider seeking technical support or consulting forums for specific troubleshooting advice based on your setup.
1/3/2024 2:06:47 AM • Peavey Music • Answered on Jan 03, 2024
2answers
Peavey 14 bt mixer won't pan. Keeps sending signal to both outputs
If your Peavey 14 BT mixer is not allowing you to pan the audio signal and is sending the same signal to both outputs, there could be a few potential reasons for this issue. Here are some troubleshooting steps you can take to address the problem: 1. **Check the Pan Controls:** Make sure you're using the correct pan controls for the channels you're trying to pan. The pan controls are typically knobs labeled "Pan" or "Balance" on each channel strip. Ensure that they're set to the desired positions. 2. **Reset Pan Controls:** If you've already adjusted the pan controls and they're not working as expected, try resetting them to their center positions. This can help eliminate any accidental settings that might be causing the issue. 3. **Channel Routing:** Some mixers have routing options that can affect panning. Check if there are any routing switches or buttons that might be affecting the signal routing for each channel. 4. **Mono/Stereo Mode:** Some mixers have a mono/stereo mode switch that can affect panning. Make sure the mixer is in the appropriate mode for your setup. 5. **Master Pan Control:** Ensure that the master stereo output pan control is set to the center position. If it's panned to one side, it can affect the overall stereo output. 6. **Test Different Channels:** Try panning different channels to see if the issue is specific to one channel or affecting multiple channels. 7. **Firmware/Software Update:** If your mixer has digital components or software control, check if there are any firmware updates available. Sometimes, software updates can address functionality issues. 8. **Physical Damage or Wear:** Inspect the pan controls and associated circuitry for any physical damage or wear that could be causing the issue. 9. **Factory Reset:** If none of the above steps resolve the issue, you might consider performing a factory reset on the mixer. Be sure to back up any important settings before doing this. 10. **Professional Service:** If the problem persists after trying these steps, it might be a more complex internal issue that requires professional servicing. Contact Peavey's customer support or a qualified audio technician for further assistance. Remember that the exact steps and controls can vary depending on the model of your Peavey mixer. Refer to the user manual for your specific model for more detailed information on troubleshooting and operation.
8/20/2023 2:15:59 PM • Peavey Music • Answered on Aug 20, 2023
Serial number on my Peavey guitar?
My guess is 1985. I think the T-60 was made from 1978 to 1988. I can't find your number in the Peavey finder so I jumped to the following chart where I just rather made up where in might fit. I'm not sure if even peavey can help. https://www.guitarsite.com/database/Guitars/rec/2986/wwwboard/messages/41.shtml https://peavey.com/c/Support
2/24/2023 7:59:30 PM • Peavey Music • Answered on Feb 24, 2023
Does the peavey xr-600b have phantom power
It does not have built-in phantom power. Phantom power is a method used to provide power to condenser microphones and other devices that require a small amount of power to operate. It is important to note that the XR-600B have XLR inputs which are typically used for condenser microphones that require phantom power but it does not provide this feature. If you want to use a condenser microphone with the XR-600B, you'll need an external phantom power supply or an audio interface that provides phantom power.
1/12/2023 8:34:18 PM • Peavey Music • Answered on Jan 12, 2023
Peavey XR 1220 Powered Mixer Mixer Powered Logo
18 questions posted
Top Peavey Music Experts
NOEL
NOEL
Ngoro
Are you a Peavey Music Expert? Answer questions, earn points and help others
View Most Popular
Peavey Music
  • Peavey Music
Most Popular Question
peavey xr1220 when turn power switch
  • Music
