20 Most Recent
Dell Microsoft Windows XP Home Edition Questions & Answers
Im need offiice 2010 serial key code
It's hard to get a serial key code for Office 2010 since Microsoft have encryption code within the hidden area of the software. The only way is to buy one. Which is a pain in the ****, But you can use Office 2010 for about 10 to 15 says free before it starts closing down on you.
RE: Background designs: I have desktopbackground
To remove a background desktop theme from the list, simply erase the picture itself from their current location.
Best way to find out is to perform a Search of all pictures on your pc, and when you find it, just delete it.
Please don't forget to rate this answer if it helps.
I bought a pc from
What is the computer model? NOT the operating system, but the numbers on the back of the computer itself. Inspiron, Dimension, Optiplex, etc. and model #
Create bootable XP disc
Dell only allows you to make 1 BACKUP Disk. but any Genuine XP iso. is bootable.... infact any genuine OS.iso is bootable... and DELL should auto boot to DVD when you insert the media, and reboot.
Lost password
insert boot media, when you get to install select REPAIR. Turn internet off, and that makes a NEW LOCAL Account and does not need a password, then you can set as Admin then Delete the old USER or you can simply to to Change Password.
How do i removea virus from my window xp beacuse my computer i so so slow
Go to bleepingcomputers.com to read up on thus subject.i usually use ccleaner (free) to clear up all the bad stuff generated in browsers to start with.then I run malwarebytes.this usually makes things right but if not then as a last resort try using the combofix from bleeping computers.this automatically run through several similar programmes and straightens out the nasty stuff that sometimes gets it's way into the system settings without your consent.lastly upgrade you ram if you can.when you use cleaner you can disable or delete some startup programmes that use up resources or do scans in the background that are quite unnecessary that can cause machine to chew slowly.
How do I reinstall big fish games?
try running the installer in compatibility mode (right-click installer and left-click troubleshoot compatibility.) If you get the smartscreen filter where it's blocked, click More Info then run anyways.
