20 Most Recent Mackie Onyx 1220i Onyx1220i Onyx-1220-i Onyx1220 Mixer Questions & Answers
Firewire connection failed during Onyx
I would try re-installing the drivers:
http://www.mackie.com/products/onyxiseries/drivers/
And go for a firmware install as opposed to an upgrade, if it failed halfway through the upgrade you will need to load the firmware on from scratch.
7/1/2011 5:57:46 AM • Mackie Onyx... • Answered on Jul 01, 2011
0answers
While the Mackie Onyx 1220i
OK... first thing is to DUMP ALL anti-virus and Anti_spyware and real time defragging programs as these resource hogs **** processing away from teh sound generation. Also is you are recording at the same time, if your disk is fragmented requiring a lot of head movement to record the time lags can cause buffer underruns and break up of audio... and eventually having the audio program "crashing" due to lack of throughput.
When doing audio work suspend all the resource hogs like the above mentioned programs. It is a good idea when recording CD's as well.
2/11/2011 5:31:25 AM • Mackie Onyx... • Answered on Feb 11, 2011
I have a mackie 1220i onyx mixer, but i cant get
What is the setup you are using. What mics (make and model). What are the settings for the channels? With this info, I should be able to assist.
Please update this.
Thanks,
Dan
1/27/2011 2:37:07 AM • Mackie Onyx... • Answered on Jan 27, 2011
Mackie 1400 SN:AH15857 Hot light on. Amp also works then goes quite then pops back on to normal.
Contact Mackie direct. They will know which component is failing. Link to the company for one of their powered speakers.
Thump215 15" 1400W Powered Loudspeaker
Mackie https://mackie.com > loudspeakers > thump-series-2022 The Mackie Thump215 15" 1400W Powered Loudspeaker brings the bass for DJs, venues, bands, and more and features a feedback eliminator and music ducking. //
1/20/2024 12:07:39 PM • Mackie Music • Answered on Jan 20, 2024
My aux 1 on my Mackie 1608 stopped working.Any ideas?
4/17/2023 4:15:13 PM • Mackie Music • Answered on Apr 17, 2023
My Mackie SR1530 is powering on but no sound.
If your Mackie SR1530 is powering on but you're not getting any sound, there could be a number of potential causes. Here are a few things you can try to troubleshoot the issue:
  1. Check your connections: Make sure that all cables are properly connected and securely plugged in. Check both the cables going into the speaker and the cables that are connected to your audio source.
  2. Check your audio source: Make sure that your audio source is turned on and properly connected. Try connecting a different audio source to the speaker to rule out issues with the source.
  3. Check the volume levels: Make sure that the volume on both your audio source and the speaker are turned up. Try turning up the volume to see if you can hear anything.
  4. Check the input settings: Make sure that the input settings on the speaker are correct. For example, if you are using an XLR cable, make sure that the input on the speaker is set to XLR.
  5. Test the speaker with a different audio source: If you have access to another audio source, try connecting it to the speaker to see if you can get any sound.
If none of these troubleshooting steps work, there may be an issue with the speaker itself. It may be a good idea to contact Mackie customer support or a qualified audio technician for further assistance.
2/25/2023 10:02:11 AM • Mackie Music • Answered on Feb 25, 2023
Mixer signals is on but qsc 1450 amp not giving any sound when main output is connected but when run aux send to amp it gives sound. What might be the problem.
If you are experiencing an issue where the QSC RMX 1450 amplifier is not giving any sound when connected to the main output of your Mackie 16 OK mixer, but works when connected to the aux send, here are some possible causes and solutions:
  1. Check the main output level on the Mackie mixer. If the level is too low or muted, this can cause the amplifier to not produce any sound. Increase the main output level on the mixer and check if the amplifier produces sound.
  2. Check the cables connecting the mixer to the amplifier. If the cables are damaged or not connected properly, this can cause the amplifier to not produce any sound. Ensure that the cables are connected securely and are not damaged or broken.
  3. Check the amplifier settings. Ensure that the amplifier is set to the correct input source and that the input gain level is set correctly. You may also want to check if there are any protection modes or limiters enabled on the amplifier.
  4. Check the speaker connections. If the speakers are not connected properly or are damaged, this can cause the amplifier to not produce any sound. Ensure that the speakers are connected correctly and are not damaged.
  5. If none of the above steps work, there may be an issue with the mixer or the amplifier. You may need to contact a qualified technician to further diagnose and repair the problem.
Remember to always follow the manufacturer's instructions and safety guidelines when working with audio equipmen
2/16/2023 9:15:52 PM • Mackie Music • Answered on Feb 16, 2023
Only one side of the mixer giving signals mackie cfx16 mixer
I would check the insert socket.
2/6/2023 7:38:19 AM • Mackie Music • Answered on Feb 06, 2023
I need diagram profx16 mackie for service .tank.
1/12/2023 3:47:55 AM • Mackie Music • Answered on Jan 12, 2023
Mackie CR1604 mixer hum on all channels
I doubt the issue will be the regulators if you have the correct voltage on them. Check where the hum is coming from. What frequency is the hum; 50/60HZ = mains hum = bad ground. 100/120HZ = power supply hum. Affected by a control somewhere maybe.
4/24/2022 7:16:15 AM • Mackie Music • Answered on Apr 24, 2022
Master volume not registering at correct level. Profx12
This unit will require an amp. I have set up several mixers and I do not watch output level numbers, you can get desired volume using amp. It does no good to drive input levels high output levels high and the turn down amp. Lower your inputs so no light flashes set master gain to -6 output and then raise amp volume. I have set up 16 mic mixer set individual levels and the feed to main mixer and controlled levels with one fader. I have taken mixes from main mixer to another mixer to control audio on video feed. A good band does not let member's set their levels . the audio person set levels, bad bands have members to set own level with resultant a mess that gets louder and produces sub par event. Remember good bands sound good and bad bands only sound louder, and bad
10/29/2021 6:53:16 PM • Mackie Music • Answered on Oct 29, 2021
2answers
Mackie 16.4.2.vlz pro. All the channel overload lights come on as soon as power is applied. Changing control/switch positions has no effect.
You probably have issues with caps in the power supply....I would check that first...open it up and look for buldging caps and replace any that you find....
9/27/2019 6:44:38 AM • Mackie Music • Answered on Sep 27, 2019
Mackie onyx 32 4 service manual
Here you go http://www.mackie.com/products/onyx4bus/pdf/Onyx_4Bus_OM.pdf This link to the manual is on the Mackie website Mackie Onyx 32 4
6/8/2019 1:37:28 PM • Mackie Music • Answered on Jun 08, 2019
Mackie dl1608 faders are hard to move when ipad docked
Hello, check if your Mackie, is with the latest Firmware update, you can get it on Mackie's official website I sent you the Mackie technical support link I hope you solve your concern Greetings Franco Dosil Hola, revisa si tu Mackie, esta con la ultima actualizacion de Firmware, puedes obtenerla en la pagina oficial de Mackie Te envio el link del soporte tecnico de Mackie Espero logres resolver tu inquietud Saludos Franco Dosil https://mackie.com/blog/support
5/3/2019 5:16:40 AM • Mackie Music • Answered on May 03, 2019
DIGRAM MACKIE PROFX16
Hello Abel, I sent you the link to download the service manual of the Mackie PROFX16 I hope you can solve the problem you have with your Mackie Greetings Franco Dosil Hola Abel, te envio el link para que descargues el manual de servicio de la Mackie PROFX16 Espero que puedas resolver el problema que tengas con tu Mackie Saludos Franco Dosil https://elektrotanya.com/mackie_profx16_profx22_sch.rar/download.html
5/3/2019 1:00:56 AM • Mackie Music • Answered on May 03, 2019
Mackie Onyx 1220i Onyx1220i Onyx-1220-i Onyx1220 Mixer Logo
6 questions posted
Top Mackie Music Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Mackie Music Expert? Answer questions, earn points and help others
View Most Popular
Mackie Music
  • Mackie Music
Most Popular Question
while mackie onyx 1220i
  • Music
