Hi
By any chance does your power supply have an on/off rocker switch on the back? Is it on? I don't mean a red voltage adjustment switch, however. If that isn't it, do you have access to another power supply to install and test? As unlikely and coincidental as it might seem, perhaps the power supply is the problem and needs replacement.
Pull off the main 20/24 pin motherboard power connector then using a small wire or a paper clip connect the green wire with one of the black wires on the 20/24 pin plug, the psu should fire up and the drives will spin up, if not then the psu is dead. When you do this test there needs to be at least one hdd/odd connected to the psu since most psus have minimum load requirements to run. Some PSUs have a rocker switch on the back that cuts the power, be sure to check that out too.
Check this helpful link to test the PSU:-
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Please get back to us if you have further query else please accept the suggestion. Thank you for contacting fixya.com
14 questions posted
