20 Most Recent Alcatel Newbridge MainStreet 3600 Multiplexer Questions & Answers
2answers
Reset newbridge 3630 data node to default
To reset a 3630 you need to go to Maint and restore the database, it will ask you which database to restore just hit esc and it will reset the database
4/5/2023 4:35:01 PM • Alcatel... • Answered on Apr 05, 2023
No connect to rs232 serial, ports PC
df1c50d.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
9/23/2017 12:58:47 AM • Alcatel... • Answered on Sep 23, 2017
0answers
2answers
Mainstreet documentation
Hello Anton, I can send you the manuals, send me your mail address..mine is [email protected]
12/11/2016 1:29:52 PM • Alcatel... • Answered on Dec 11, 2016
2answers
Alcatel Mainstreet 3600 Anphenol PINOUT
You must have a Dual E1 card that support a 120 ohm interface. There are cards for 75 and there are cards for 120 ohm. Sergio - Argentina
4/4/2016 5:48:49 AM • Alcatel... • Answered on Apr 04, 2016
2answers
Where can I buy second
HI Basil, you can get the equipment from PC.
3/20/2015 7:39:53 PM • Alcatel... • Answered on Mar 20, 2015
Reset 90-0667-05 to vt100
If you log on to SP1 using VT100 and you get garbage the port is properly set for CPSS and you will have to use a craft interface to log on talking CPSS to the node. The S1 switch on the control card is to reset the database on the node, but you can also use this to reset the SP1 port back to VT100...be very careful doing the following procedure as you can delete the database. Power down the node and press and hold in S1 then power up the node still pressing in S1, look at the the display it will after going trough it's start up process display a "0" ...release S1 and press S1 again....this will reset your SP1 to VT100 and you will be able to log on again. "0" reset SP1 and if it display a "1" and you carry on you will delete the database. As I warned you the "1" will delete the database, if for some reason you are stuck on "1" just power done the node without pressing S1 and it will restore as previous setting....good luck!!!
9/17/2014 7:48:49 AM • Alcatel... • Answered on Sep 17, 2014
Newbridge 3600 circuit signal fault
RBS is either all on or all off
6/19/2014 3:31:14 PM • Alcatel... • Answered on Jun 19, 2014
How can i configure x.21 circuit at 384kbp or above
Please let me know on what card you want to configure it for..X21DCC, RS442 or X21 DTU?
5/26/2014 12:20:16 PM • Alcatel... • Answered on May 26, 2014
0answers
Download pics to computer
right click on picture, click save as, select your file destination, click save.
12/12/2013 7:23:19 PM • Alcatel... • Answered on Dec 12, 2013
0answers
What's your problem?i am facing oblem power alarm and i can not get dial ton on my newbridge 3600 can any body help me to resolve this problem how can i check that
Is this connection between a LGS and LGE card?? if so then the only problem can be on the configuration on the two cards, both needs to be configured for "RE" remote extention.RegardsLen
11/16/2012 7:12:40 PM • Alcatel... • Answered on Nov 16, 2012
2answers
How do i remove Nmti if it affects port or frame relay resource
Hi Christina,
The problem come up or happened because the link (E1/T1...) problem or 3600 series going down e.g power down etc. The effect of it sometimes influenced the circuits mainly the circuits made by nmti software via hyperterminal, 4601A even 5620 NM (integrated NMTI).
To solve the problem first you have to clear or de-configure the configuration/cross-connect via nmti and than you connect again the circuits. Please using Alcatel 5620 NM GUI to make cross-connection or circuits (Circuits Switch Data).
Regards,
jhadori
10/22/2012 12:57:04 PM • Alcatel... • Answered on Oct 22, 2012
0answers
0answers
Alcatel Newbridge MainStreet 3600 Multiplexer Logo
64 questions posted
Top Alcatel Computers & Internet Experts
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Alcatel Computers & Internet
Most Popular Question
mainstreet documentation
  • Computers & Internet
