20 Most Recent
Soltek SL-75FRN2-L Motherboard Questions & Answers
Chevrolet check engine code 113
Intake Air Temperature Circuit High Input
The Intake Air Temperature Sensor measures the rise and fall of the air temperature inside the Intake Manifold. This provides critical data needed for the Powertrain Control Module (PCM) to control the Air Fuel Ratio, the Ignition Spark Timing and many components of the Emission Control Systems.
Code P0113 sets when the voltage signal to the PCM from the Intake Air Temperature Sensor Circuit stays above 4.5 volts while the Coolant Temperature Voltage readings are rising and falling within an appropriate range.
Common Problems That Trigger the P0113 Code are
Defective Intake Air Temperature Sensor
Dirty air filter
Defective Mass Air Flow Sensor
Faulty or corroded Intake Air Temperature Sensor wiring or connections
5/1/2014 4:58:12 PM •
Soltek...
Answered
on May 01, 2014
Need user manual
that mobo uses the nForce2 Ultra 400 Chipset most functions will be the same from a differant model using the same chipset.
6/10/2010 4:40:10 AM •
Soltek...
Answered
on Jun 10, 2010
Hello!
I'm looking for a Soltek
Hi.
I uploaded the manual here.
I used a free upload service.
To get free download, skip the ads and wait about 40 seconds, when the counter will reach zero your free download will be enabled.
You can also have a look at the links below:
Regards
12/6/2009 4:24:42 PM •
Soltek...
Answered
on Dec 06, 2009
I'm looking for manual i need JPN1 setting pin
hello, look at the motherboard clearly or you put it under light, you will see all the jumper pins labeled with or printed with white paint, the name of each connection pins is written on the board. the speaker is far from the power switch,the reset pin is by the side of the power pin, the HDD light and the power light are opposite each other.to make things simpler, i suggest you forget about the reset and other ones and concentrate on the power pin. bridge all the pin with a screw driver to locate for the power pin i.e two pin at a time.
8/6/2009 3:40:19 PM •
Soltek...
Answered
on Aug 06, 2009
Long beep continously
One Long Beep, One Short Beep
Motherboard Problem
One Long Beep, Two Short Beeps
Video Problem
One Long Beep, Three Short Beeps
Video Problem
Three Long Beeps
Keyboard Error
Repeated Long Beeps
Memory Error
Continuous Hi-Lo Beeps
CPU OverheatingOR Continuous beep Power supply, system board, or keyboard problem
7/13/2009 6:40:33 AM •
Soltek...
Answered
on Jul 13, 2009
Bios update
The BIOS updates should be on the motherboards producer site....
But u must find out what the beeps mean. That info should be in the motherboards user manual (usually at the end), or again at the producers site. The beeps alerts u of problems detected by POST tests ... and so u'll know exactly what u're problem is
(but most probably u have a problem with the memory or video card, perhaps thay are not well mounted in the sokets )
11/30/2008 6:30:01 AM •
Soltek...
Answered
on Nov 30, 2008
Soltek SL-75FRN2-L how to connect power button..
Front panel connector in bottom right corner, if you look very closely you can see the connector info written into the motherboard in white.
If its too small you need to get the manual for your motherboard to see the connections.
6/25/2008 9:14:39 AM •
Soltek...
Answered
on Jun 25, 2008
