try taking out the red blue green cables completly out so no cables should be conected exept for the power cable then plug in the hdmi cable from the ps3 to the tv after you do that turn on the tv to hdmi input then turn on the ps3 and let it sit for a while and look at the tv while the ps3 is turned on shortly after you turned the ps3 on a message should pop up on the tv select yes then set the settings and that should work let me know if it dosent
When playing a game? If so, you may need to replace your laser:
There are many videos on youtube if you
would like to do it yourself (I would advise you not to). I recommend
that you find a technician who has experience. There are many things
that can go wrong.
If you do, you must disassemble your
drive and take out the laser to see exactly which laser you will need
to purchase
I would get professional 'live' help on this issue.
first you need to go to settings and then you need to scroll down until you see an option named saved data games/app settngs click on it and then if your game version is ps5 then go there and if it is ps4 go there, then there will be an option named console storage click and press "R1" on your controller to go to an heading named "delete" then select the game in which you want to erase the data and then select the option "delete", the game data will be deleted
First, from your computer click the Download Link
to download the latest PS4 Update. Make sure you don't rename the downloaded file.
After download, plug your USB onto you Computer. Open the USB and make a folder inside named PS4 (you need to use Uppercase letters). Inside that folder create another folder named UPDATE. Then, just take the PS4UPDATE.PUP file you downloaded from the provided link and put it inside the UPDATE folder.
After that you just connect your USB with your PS4, and then from the Main Screen of your PS4 go to Settings -> System Software Update and just follow the instructions on-screen.
PS: Make sure you DO NOT turn off the console or remove the USB from the PS4 while the update is taking place, otherwise the system may be come temporarily or permanently damaged.
Download Link
http://dus01.ps4.update.playstation.net/update/ps4/image/2015_0625/sys_4f1c6d8597242ff346612773ffbc10ad/PS4UPDATE.PUP
The PS4 will allow you to use an external drive to store data other than games. If you put a game on an external drive, it wont work. The drive in the unit is 500Gb
NBA 2K17 is not free, however there is a free mini-game called NBA2K17: The Prelude. This mini-game allows you to create your player to compete in the MyCareer mode. Using the mobile app, you can scan your face and import it in the game. You decide which college to play for, and can even decide your own nickname. You don't play an entire college career, but a few key games that will help determine your draft status. You don't even play full games, only two 6 minute halves. Depending on how well you do, you will either play the whole game, or get subbed out. After each game, your draft status will either rise or fall, depending on how well you played. After you finish, you are prompted to buy the game in order to see where you end up in the draft.
