20 Most Recent Activision Transformers The Game for Windows Questions & Answers
Encrypted files password
password of encrypted file of transformers the game
1/20/2019 9:39:39 AM • Activision... • Answered on Jan 20, 2019
How to fix xinput1_3 error
Download and install ... DirectX End-User Runtime Web Installer from Microsoft's website. Download and Install DirectX9 End User Runtime Install DirectX DX9 Then run windows update on your machine.
3/17/2015 1:18:51 PM • Activision... • Answered on Mar 17, 2015
I can't play transformers activision pc game.when i open the game ,after sometime i can see some logos of some company then returns to desktop.game will be closed. can you help me
I read up on this and it seems that you may need to update your video card drivers. I think there may be a codec with compatibility issues.
3/17/2015 12:55:24 PM • Activision... • Answered on Mar 17, 2015
Password of encrypted file
If you purchase the game you will not have this issue. The file you downloaded was acquired illegally and will require completing scams and giving phishers easy access to your personal information. Then the game will most likely not work once you open it anyways. Good luck!
4/10/2014 6:09:53 PM • Activision... • Answered on Apr 10, 2014
Transformer the game
In doing some research on this issue I've found it to be a common occurrence. Some suggestions state to try adjusting your video settings, but others state it's a bug and manually closing the application is the only way to get around it.
1/3/2014 9:57:54 AM • Activision... • Answered on Jan 03, 2014
WE are trying to play
I've never heard of this kind of problem but,since it crashes at a certain level the reason could be,you don't have all the files of the game.So reinstall the game and see if it works.
6/8/2011 11:23:33 AM • Activision... • Answered on Jun 08, 2011
I want to play Transformers
It looks like your Video Card doesn't meet the minimum system requirements. The only way to get this fixed is by upgrading your video card that supports at leat Pixel Shader 1.1.
Hope this helps.
2/22/2011 3:50:25 AM • Activision... • Answered on Feb 22, 2011
2answers
Cant find games for gba pc emulator
Google
GBa Emulator Roms
or go to
http://www.gameboy-advance-roms.com/go/to.htm?http://www.doperoms.com/
12/27/2018 5:43:12 AM • Activision Video... • Answered on Dec 27, 2018
We have a wireless drum kit for band hero game on
Check the paperwork if the unit is still under warranty and if so return it...
12/18/2017 10:54:48 PM • Activision Video... • Answered on Dec 18, 2017
0answers
I am having a problem.
Direct3D 6? Wow, the game must be way older than your computer. You probably installed DirectX 10 or later. There were major changes after DirectX 9. The software routines to manage graphics hardware acceleration through DirectX 10 or newer are probably very different from DirectX 6, so the game's graphic controller interface can't find them. Try going into the game properties (right-click on the main executable file and select Properties from the pop-up menu). Set it to run in XP compatibility mode and see what happens. Check to see if the game has the option to run without hardware acceleration. If this provides acceptable performance, that is your answer. If necessary (and if Microsoft still makes it available), try installing DirectX 6. Vista may snag on it and make you remove it and reinstall a newer version, but it's worth a shot if the other fixes don't work.
7/3/2017 4:30:33 AM • Activision Video... • Answered on Jul 03, 2017
Bought the season pass for call of duty ghost and it is not working
Hello. If you have problems with your game you should contact Activision support. Someone there will be able to help you. Good luck! Activision Customer Support Contact Us
11/25/2015 4:30:18 AM • Activision Video... • Answered on Nov 25, 2015
Someone I play with was hacked and banned while he was in school
Hello. If your friend has been hacked then you should contact activision support and explain the situation. Someone there will be able to help you. Good luck. Activision Customer Support Contact Us
11/25/2015 4:28:15 AM • Activision Video... • Answered on Nov 25, 2015
I have a wii mini can I still get netflex on it
Good afternoon James, Unfortunately you do not have internet access; no streaming, no surfing, and no multi-player will be available to you. I would cite the manual, but there is not mention of internet due to its lack thereof. https://www.nintendo.com/consumer/downloads/WiiMiniOpMn_RVO_en.pdf
7/2/2015 10:34:16 PM • Activision Video... • Answered on Jul 02, 2015
Activision Transformers The Game for Windows Logo
13 questions posted
Top Activision Video Game Consoles & Games Experts
Sean Wright
Sean Wright
MegaByteMe
MegaByteMe
john h
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • Activision Video Game Consoles & Games
Most Popular Question
transformer game
  • Video Game Consoles & Games
