20 Most Recent Canon G12 Digital Camera Questions & Answers
Canon g12 freeze focus
this camera must be fallen, in such situations the lens motor/gears struck. open it loosen the motor and peripheral parts.
9/10/2017 6:59:17 PM • Canon G12... • Answered on Sep 10, 2017
2answers
Camera says "communication error" when trying to transfer images to computer. Why?
Try NOT connecting your camera to your computer. The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
1/4/2016 8:21:35 PM • Canon G12... • Answered on Jan 04, 2016
5answers
Zoom and menu buttons not working
Assuming it isn't physical damage caused by a drop or by spills then it will probably be the connection on the sub board. The buttons are mounted on a small board that gets connected by a ribbon cable to the main board in the G series. The cables do come loose in electronics (and cameras) and the connection can corrode.If you hadn't banged or dropped it or spilled then corrosion would look more likely. Unfortunately the G's require almost total dis-assembly to get at this board. A regional repair depot or Canon can look at it for you.You should be able to get this one done on a flat rate repair if you do not have any warranty. If this were casued by a spill or just humidity etc then the camera has to be either put in a partial vacuum or disassembled to get that out. Applying heat even for a few weeks will not work as the body inside sees no airflow and may cause additional damage. Best advice on this is to call the Canon support line and take to them about getting it repaired. I don't know your location but if you go to www.canon.com and pick your location then click on support you will see toll free support phone numbers for your area. Give them a call and they can either tell you a local shop to take it to or to send it to them etc. The local shop will be a certified repair depot so doesn't matter and will do the flat rate as well.
12/21/2015 4:00:22 AM • Canon G12... • Answered on Dec 21, 2015
Canon G12 display problem
Replace the LCD cable. Not expensive and easy to replace. Try eBay for a replacement.
11/14/2015 1:42:24 AM • Canon G12... • Answered on Nov 14, 2015
Lens could not be retracted back
Try this it may work. Turn on the camera. While still on remove the battery. Leave for 30 secs and reinstall the battery while still in on mode. Switch off and switch on. This may work to reset.
10/2/2015 6:21:59 PM • Canon G12... • Answered on Oct 02, 2015
Lens is out and will not move. When I turn the camera on the message on a black screen reads " Lens Error Will Shut Down Automatically. Restart camera". Help needed!
Let discharge battery, charge it and try,Connect it to your computer and tryIf still get the error I see no way to solve this problem through a Q/A forum. Your camera is defective and you should consult a repair service about repair cost. You should evaluate if worth to invest repairing it or might be a better option to sell it for "parts" to repair other cameras and buy a new one.
7/20/2015 1:32:12 PM • Canon G12... • Answered on Jul 20, 2015
Camera does not have format option
Please review page 22 of the owner's manual and report your result. We will then go from there.
6/30/2015 1:11:02 AM • Canon G12... • Answered on Jun 30, 2015
0answers
3answers
"I have a Canon Powershot G12 Camera. The LCD
This is a common problem on the Canon G12. It has something to do with the CCD Sensor yet Canon doesn't acknowledge it to be a problem. To get this fixed, I would suggest: www.camerasandparts.com All they specialize in is the Canons. It's $89 through them to fix that common problem, plus they service the camera and do the internal correction to prevent this from reoccurring again on the camera. They tend to be the best bet for the Canon's, definitely for this issue, they'd be the place. Good luck
2/9/2015 7:01:18 PM • Canon G12... • Answered on Feb 09, 2015
My canon powershot g12 lcd works fine but the photos are all 'whited' out
You may have the exposure compensation settings overexposing you images. Since it compensates without affecting the image prior to shooting, you won't see it until after the image is taken. Check that and the flash exposure compensation too.
2/5/2015 6:46:32 PM • Canon G12... • Answered on Feb 05, 2015
5answers
Hi! The screen of my canon powershot G12 is black,
Get it serviced by a professional shop. It's probably the CCD that is giving you a problem, those are the classic symptoms of that sensor failing. If you need help with it, try this site: www.camerasandparts.com They are the place for help with the Canon Powershots. That's all they specialize in, they do excellent work and they're about have of what Canon wants to repair these cameras. They're the place for help with a Powershot. Best of luck with it.
2/5/2015 6:44:25 PM • Canon G12... • Answered on Feb 05, 2015
3answers
Canon G12 Digital Camera canon g12
CCD Problem. Go to this site: www.CamerasAndParts.com They have a fix for this problem on the G12. They are super for help with the Canons.
2/5/2015 6:37:27 PM • Canon G12... • Answered on Feb 05, 2015
G12 says card error card locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
1/28/2015 8:10:02 PM • Canon G12... • Answered on Jan 28, 2015
2answers
My G12 lens says error
The only real way to fix this is to have it serviced. It's not expensive depending where you go. The best place for repairs on the Canons and the only place we really recommend is: www.CamerasAndParts.com They only work on Canons and they are about half the cost of most shops. Plus, this place includes everything right down to the cleaning and service for the camera. They are excellent, your best bet since you have a Canon.
1/28/2015 8:07:07 PM • Canon G12... • Answered on Jan 28, 2015
Buttons locking
If taking the battery out for at least 15 minutes, pressing the power button without the battery in the camera, and then after you put the battery in the camera doesn't work to fix a problem you can reset the camera to factory settings like this:
  1. Press the "Menu" button. Press the right arrow once to highlight the "Setup" menu.
  2. Press the down arrow five times to select "Reset All." Press the "Set" button.
  3. Press the right arrow button once to select "OK." Press "Set."
1/15/2015 1:03:58 PM • Canon G12... • Answered on Jan 15, 2015
My display off when i flip the lcd
The Display button toggles the information shown on the LCD (or turns it off entirely). Make sure you haven't inadvertently pressed it and turned off the display. It works as follows:
  • Press once for Normal view in LCD viewfinder
  • Press twice to turn on Rule of Thirds grid lines
  • Press three times to turn off LCD display
  • Press and hold 1 sec. to decrease/increase LCD brightness
1/15/2015 1:00:44 PM • Canon G12... • Answered on Jan 15, 2015
I have lost the sound when using video. Any ideas?
Try pushing the up arrow on the control wheel if you hear no sound during playback of a movie from the G12. The up/down arrows control audio volume during playback.
1/15/2015 12:59:39 PM • Canon G12... • Answered on Jan 15, 2015
Reset original settings
1/15/2015 12:58:00 PM • Canon G12... • Answered on Jan 15, 2015
Canon G12 Digital Camera Logo
122 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Canon Cameras
  • Canon Cameras
Most Popular Question
g12 lens says error
  • Cameras
