20 Most Recent
Zenith P60W26 60 in. HD-Ready Plasma Television Questions & Answers
How to factory rest zenith plasma tv
Here give this a try and hope this helps.
- Press the "Menu" button on your remote control. Use the up and down arrow buttons to highlight the video option. Press the arrow that points to the right to select the video option.
- Use the up and down arrow to highlight the video reset option. Push the right arrow button on the remote control to select video reset.
- Press the right arrow button on the remote control to return the video to original values.
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/jason_70466cb634a57543
Vertical line in centre of my zenith plasma p60w26 tv
I also have this problem, but with 2 black vertical lines on the right side of screen half way through. Lines disappear from time to time but reappear. Is there anything I can do to get rid of them. Help me out please
.... Thank You.
I have a Zenith P60W26.
Hi Jim,
This is very common faults in plasma tv. Bad news because this kind of symptoms has a lot of parts that are going to consider which was gone to malfunction. The boards most likely to fail are the control board, sustain boards, and the power supply board. They are chain for processing the image and feed to the plasma panel. First the unit must isolate from loose connections and bad solder joints because it will produce same symptoms. All the cable connectors must be pull-out and then re-insert and ensure the connections. Power supply board is prone from bad solder joints (cracked/dried/cold solder) because this is the warmest/hard working among the boards. This is hard to spot, I would advice you to work in the brightest area or used table/portable lamp and magnifying glass and re-solder it on the board.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified tv technician or send it to reputable repair shop.
Also, check if your unit is still under warranty/extended warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the back cover(it will void the warranty).
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Hdmi port not working for ps3
believe it or not it might be your tv. mine did the exact same thing and i thought it was my ps3 but who wlda guessed its the tv lol. soo heres what you do. leave ur ps3 plugged in to your tv through hdmi, then all you do is unplug your tv from the wall, and wait for about 20 mins then volia!!!!! hmdi at its best. i do not know how it works but it does and i hav not had a problem since.
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue:
Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly.
Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate.
Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs.
Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components.
If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
