20 Most Recent
Caterpillar 6" Honey Holton Soft Toe boots P73270 for Men Questions & Answers
Does caterpillar have a place
They can be replaced at shoe repair shops near you. There is no place that Caterpillar has to replace soles at least around here. Ask if they have Vibram soles. They last longer than similar ones.
Bots 8" p71866
What did happen? Did you get a bot on the shoe? It may change the cosmetics to have a bot, but you must rip the bot off to get the botfly larva out.
The colour has come out
caterpillars come in many different colors...please specify what critter you are referring to
Oakley screw fell out
1. PLACE THE FRAME ON A FLAT SURFACE WITH THE SCREW HOLE FACING UP.
2. TAKE THE SMALL SCREWDRIVER AND INSERT THE REPLACEMENT SCREW INTO THE HOLE.
3. TURN THE SCREWDRIVER CLOCKWISE TO TIGHTEN THE SCREW UNTIL IT IS SECURE.
4. ONCE THE SCREW IS IN PLACE, MAKE SURE IT IS TIGHT ENOUGH TO HOLD THE FRAME TOGETHER.
3/28/2024 10:20:58 AM •
Clothing...
Answered
23 hours ago
How much would getting a wedding dress made cost?
The cost of getting a wedding dress made can vary greatly depending on factors like the design complexity, quality of materials, and the expertise of the designer. On average, it can range from a few hundred to several thousand dollars. It's important to consider your budget and discuss pricing with the designer to find the best option for you. For best designer lehengas, saree and ethnic wear you can check Mirraw Luxe online. Visit now: https://www.mirrawluxe.com/trends/wedding
3/8/2024 1:22:32 PM •
Clothing...
Answered
on Mar 08, 2024
How to clean white shoes properly?
Cleaning white shoes can help maintain their appearance and keep them looking fresh. Here's a step-by-step guide on how to clean white shoes properly:Materials you'll need:1. Mild soap or detergent2. Soft brush or toothbrush3. White vinegar or baking soda (optional)4. Water5. Clean cloth or sponge6. Old newspapers or paper towels Steps:1. Remove Loose Dirt: Knock your shoes together or use a brush to remove loose dirt and debris. You can also use a soft cloth to wipe away any surface dirt.2. Remove Laces: Take off the shoelaces. You can either clean them separately or replace them if they are too dirty or worn.3. Pre-treat Stains:If there are stubborn stains, pre-treat them with a mixture of water and a small amount of mild soap or detergent. You can also use a paste made from baking soda and water for tougher stains.4. Soak Laces:If you removed the laces, soak them in a mixture of warm water and mild soap. You can also add a bit of baking soda or white vinegar to help with stains. After soaking, scrub them with a brush or toothbrush, rinse, and let them air dry.5. Wash Shoes: Mix warm water with a small amount of mild soap or detergent. Use a soft brush or toothbrush to scrub the shoes gently. Pay extra attention to stained or dirty areas. Be careful not to use a brush with stiff bristles, as it may damage the shoe material.6. Rinse Thoroughly:Wipe off any soap or detergent with a clean, damp cloth or sponge. Make sure to remove all residue.7. Dry Properly:Stuff your shoes with crumpled newspaper or paper towels to help them retain their shape and absorb moisture. Let them air dry in a well-ventilated area. Avoid direct heat sources like radiators or sunlight, as this can cause the shoes to yellow.8. Clean Soles:Clean the soles of your shoes separately. You can use an old toothbrush or a small brush to scrub away dirt and grime. A mixture of water and mild soap or a specialized sole cleaner can be effective.9. Protect and Maintain: Consider applying a stain and water repellent spray to protect your white shoes from future stains. Regularly clean your shoes to prevent dirt buildup.10. Polish (for Leather Shoes):If your white shoes are made of leather, you can use a white shoe polish to restore their shine. Make sure to follow the instructions on the polish container.Remember, prevention is key. Try to avoid wearing your white shoes in muddy or extremely dirty conditions, and clean them regularly to keep them looking their best.
12/28/2023 4:24:01 PM •
Clothing...
Answered
on Dec 28, 2023
Are you searching for Handcrafted Polki Jewellery in India?
Polki jewellery is a traditional Indian jewellery style that uses uncut diamonds in its designs. It is a popular choice for weddings and special occasions. There are many Indian jewellery designers and brands that offer handcrafted Polki jewellery, both online and in physical stores. Some popular options include Sabyasachi, Amrapali, and Tanishq.
2/25/2023 9:53:01 AM •
Clothing...
Answered
on Feb 25, 2023
