20 Most Recent InFocus ScreenPlay 5700 Multimedia Projector Questions & Answers
2answers
Power is on but wwont turn off, no response to functions
Im sorry that we got disconnected. I believe that this may solve your problem. If it does not, leave a comment on this question and i can either chat with you via the comments on this question, email, or phone. I wont be able to get back on my computer till around 5 oclock EST tomorow. But I will check back on this question then to see if you left me a comment. Let me know if it works.
~evsp341995
3/28/2015 9:40:54 PM • InFocus... • Answered on Mar 28, 2015
What causes white vertical lines on dlp projector?
Possible fault on the mother board as there are noise on the LCD display. You might need help to sort this out if the fault does not clear even after the lamp works for some times.
3/19/2015 11:53:22 AM • InFocus... • Answered on Mar 19, 2015
Optoma gt700 makes loud high pitched noise then overheats
Could be bad bearings in the fan they are replaceable.
6/11/2014 12:51:16 PM • InFocus... • Answered on Jun 11, 2014
Horizontal bar appears on screen from screeplay
That's usually from input device or cable. I had a DVD player that caused that. Did you try plugging another device into that input. What input are you using?
12/10/2013 1:32:30 PM • InFocus... • Answered on Dec 10, 2013
0answers
Filter infocus 5700
Be the first to answer 11/21/2013 5:46:36 AM • InFocus... • Posted on Nov 21, 2013Be the first to answer
0answers
Locked in searching source
Click menu, go to the third screen, unclick source lock, and select the proper source, remember that the format need to be setup according to your output that's coming in to the projector. Under each source format there are sub menus for various input types as well.Tony Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
2/10/2013 7:42:57 AM • InFocus... • Answered on Feb 10, 2013
I have audio and can bring up the menu but no picture
what input are you using? if you are using vga, the cable may be bad. if component, make sure the h and v are not switched around. if rgb, make sure the blue and green are not switched. the green carries the h+v info. if composite, check the video cable. if all else fails, you may need to replace the main board.
8/25/2012 5:14:49 PM • InFocus... • Answered on Aug 25, 2012
Infocus 5700 will not power on
Try re-installing the driver for the projector. It might help.
7/2/2012 2:43:26 PM • InFocus... • Answered on Jul 02, 2012
Need Manoal
I have the manual with me. If you can give your email address then I'll sent the manual of InFocus ScreenPlay 5700 to that email address. Or you can down load the manual from the following link.
http://www.retrevo.com/support/InFocus-SP5700-Projectors-manual/id/1081ag706/t/2/
OK
10/10/2011 10:49:05 PM • InFocus... • Answered on Oct 10, 2011
Where is the light engine located? Saw that you
The entire lens assy and the colorwheel with the light tunnel are considered the engine. The connection is on the back end of the lens. Just look to see how the main board is connected to it and disconnect and then reseat it.
10/10/2011 3:57:42 PM • InFocus... • Answered on Oct 10, 2011
My Infocus 5700 won't power
We can fix this. I believe you are handy enough to fix the power supply of this masterpiece.
I had 100% the same problem and finally figured it out. The problem is with one of the capacitors, and after lots of trial and error, and asking for advice, here it is: The capacitor is "C16" - a small blue electrolytic - 100uf 16v. It is in the center of the power supply board partially hidden by a black heat sink and the large silver chunk of metal.
Swapped for a 25v 100uf I had lying around and she works like a charm now.
Here's how it looked like on mine:
images?q=tbn:and9gcte64-3vvp7h6vtswd6pxijyyxdvcyifqgbtov0jpszkmueqklupg
8/24/2011 10:04:49 PM • InFocus... • Answered on Aug 24, 2011
Blinking red light. projector won't turn on
The lamp life may have exceeded its safe limit, check your manual as you may have to press a specific button on the unit/remote for a length of time to reset it.
Good luck
8/5/2011 10:53:55 AM • InFocus... • Answered on Aug 05, 2011
InFocus ScreenPlay 5700 Multimedia Projector Logo
96 questions posted
Top InFocus Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • InFocus Office Equipment & Supplies
Most Popular Question
causes white vertical lines dlp
  • Office Equipment & Supplies
