20 Most Recent
Kyocera KM-1505 Copier Questions & Answers
Error E354 in copier ir2016
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Kyocera Mita 1635 Copier Printing Very Light Copies
Is one side lighter then the other side of the copy? Meaning uneven copy darkness? If so, I believe the problem is that one or both sides of the drum cartridge and the developer are not connected correctly. The two parts need to be close togather to make a nice dark copy. This model has a very wierd drum unit and has a defect that one or both side of the drum unit locking tabs break and you get very light or blank copies. It's some what coastly to replace the whole unit... That would be a worse case.... If it is just on one side you might be able to push on the cover on the side that is light. If the copies come out better. One side is broken..I would fold up some paper and make a wedge to push the catridges closer. Good Luck
Error c6020
this is a fuser error. go into service mode( in the copier standby press 10871087 on the keypad) and go to u163 fuser error reset. If this does not work you might have to consult a service centre.
Kyocera mita error codes of KM 1500
Hello sir; The error code you display A3200 is not available in our menual, we do have C3200 , if that's correct, it means exposure lamp burn out ( not on), replace it, or thermos fuse out.
Black cq when using document feeder
clean the slit glass its the small maybe two inch wide glass to the left of the main glass clean it good use windex or alcohol that will get rid of you problem have a great day
How to add powder?
Don't Worry, It's simple ! You Just have to do is:
1)Buy a toner Bottle, its dust and be careful with it.
2) Pull out the toner Cartridge (You know where it is?)
3) There is a small cover with a screws , open it and remove all dust inside.
4) Fill with new ink and screw up the cover,
5) put cartridge back on printer and start.
Enjoy ! write back if any problems.
