20 Most Recent
Lexmark Wheelwriter 1000 Typewriter Questions & Answers
Wheelwriter word spacing
On all Wheelwriters the spacing is set by the printwheel to change spacing change the wheel. 19 pitch to 12 pitch or visa versa.
DickyO
8/7/2018 8:14:05 PM •
Lexmark...
Answered
on Aug 07, 2018
LEXMARK MS610DN CHANGE PITCH FROM 10 T0 12
On the Wheelwriter machines, it is the printwheel that determines what pitch you are in. The wheel has holes in it that a part "reads" the holes when the machine is turned on or when the printwheel is changed. You can not manually change pitch.
6/2/2015 5:34:00 PM •
Lexmark...
Answered
on Jun 02, 2015
After typing on a line and i hit return it stops wherever it wants and won't let me release the margin
Your problem is probably the transport motor. It is the one that makes the carriage go back and forth. There is probably a bind in the carriage. Look at the metal shaft that runs through the carriage. Cleaning this shaft with contact cleaner and then putting a thin amount of oil on the shaft. (A very small amount mind you). You can clean the area where the shaft runs through the carriage on both sides. This will help with any binds the carriage may cause. If the problem continues, then the machine should have the motor serviced or replaced.
1/7/2015 1:47:24 AM •
Lexmark...
Answered
on Jan 07, 2015
