One of the products on our list of 'essentials' before the arrival of the baby is a bathtub. Of course, as with everything we find in the childcare section, we find many options and in the end, we become a mess when deciding. As I just went through that moment, I'm going to show you a list I made and the characteristics of each of them.
Bath Chandelier Cuddle & Bubble by Chicco
It is a folding bathtub-changer. In changing mode it offers a lot of comfort to newborns because it has a soft padding and reducer, and in bathtub mode, it is quite comfortable due to its dimensions. Once folded, it is compact and very easy to transport due to the wheels it incorporates.
It includes a large number of accessories and compartments to have everything at hand and its height is adjusted in three different positions depending on the needs of the mother. Its price is 99 euros.
Flexi Bath de Stokke
It is one of the most famous folding bathtubs because it is one of the most compacts that exists. It offers a lightweight and a compact size, which makes it an ideal tub for traveling. The bathtub is free of harmful substances as it is made of polypropylene (PP) free of phthalates and BPA and thermoplastic elastomer (TPE).
As an additional accessory, it contains a hammock holder for newborns in solid plastic. Its price is 41 euros and the support for newborn 16 euros.
Bath Bato
It is a very modern design bathtub. It is characterized by having a double wall that makes the water take time to cool down, so it is ideal even for very long baths. It has a stopper that changes color when the water is at an adequate temperature and a support that allows us to use it while standing, so it is quite practical in that sense. The price of the bathtub and the support is approximately 60 euros each.
Innovations Slim Tub
It is a bathtub with an anatomical shape and designed to facilitate bathing during the first months. It is made of non-toxic PVC and is recommended for babies from 0 to 12 months. It contains an optional support to be able to give standing baths and its price is 28 euros.
Mof Chof Chof Foldable Bath
It is a folding bathtub with a flexible tray made of transparent and resistant PVC that allows an optimal folding. It contains an aluminum support with double rivet with protected legs with the anti-slip system, although it is characterized by its low weight, good folding and carrying bag, so it is another good option to take on a trip.
Another feature that makes it a different bathtub is its double-use chassis, as it can be used as a standing bathtub and also with accessories approved for various widths of the bathtub. Its price is approximately 60 euros.
Bath Beaba de Cameleo
It is a bathtub with a design that I like very much: round shape and flexible and non-slip material for the maximum comfort of the baby. It has wide edges, a side shower support and drains plug, in addition to a support (optional, which is purchased separately), to be able to give standing baths. Its price is approximately 45 euros.
Bathtub shower maxi
It is a bathtub for shower tray and has a good size (from 70 cm to 90 cm), so it is perfect to bathe two babies at the same time. Its system is telescopic, extendable and can be adapted to the appropriate size of your shower tray, both in height and width. Its height is also adjustable (from 40 to 60 cm.) And is recommended for babies and even for children of 7 years.
Its structure is made of aluminum tubes and the fabric is washable, made of polyester with a layer of polyurethane, so its weight is not exaggerated (2.75 kg.). It can also be folded behind a door or against the wall 10cm wide.
In another post, I will tell you which was my choice and if I am happy or not with it. What type of bathtub did you choose? Would you repeat with her?
Top 10 Best Toddler Baby Bath Tub Reviews You Need To Know baby product 24
If the sending and receiving units are going through walls or one is upstairs and the other is downstairs it may not have the range you need as walls will knock down the signal. Sounds like your right on the edge of the range maybe try to move the units closer together if possible and see what happens.
