20 Most Recent
Digipower Battery Charger Questions & Answers
How do I charge my battery for my samsung 3
plug charger into your phone and in wall socket, should take about 7 to 9 hours, just press big button on phone now and then if you want to check how much has charged. don't worry about over charging it wont cos it turns of when fully charged,
10/3/2014 5:28:33 PM •
Digipower...
Answered
on Oct 03, 2014
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.Panasonic DMW-BCG10 Battery
6/5/2012 12:47:27 AM •
Digipower...
Answered
on Jun 05, 2012
Hi I have a sony cyber shot digital camera model no.dsc-s950 and I would like to know if I need a what type of battery charger do I need to charge my battery,and where can I find one for cheap, also n
Here's
one source for a compatible battery charger.I can't tell whether your battery is compatible with your sister's charger since you neglected to specify the model of her camera.You should be able to use any USB cord, but I suggest you don't. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you an use any photo cataloging program, such as
Picasa.
5/11/2012 4:42:31 PM •
Digipower...
Answered
on May 11, 2012
