20 Most Recent
Pier 1 Imports Brown Pierced Metal Floor Hurricane - Small Questions & Answers
Bought 3 metal floor hurricane candle holders for
These are specially made with to suit the particular requirement and there is no way but to get this replacement from the manufacturer. the other way out is to use the two remaining ones on either sides for a brighter light and use 10" pipes of PVC or transparent tubings to give a special shade. Check this out with the availability at a plumbing store. You can cut portions on the opaque shade and use acrylic pieces to be stuck within to give an art look.
Eclipse propane floor buffer manual
I apologize, but I need more information about the specific model of the Eclipse propane floor buffer to locate the manual and provide troubleshooting steps. Can you please provide the model number or any additional details about the buffer?
How to change a rectifier on a U2000 floor buffer?
The rectifier is in the top end of the motor. Take the cover off and then the top end plate of the motor. With the bolts removed, you will have to tap and rock the plate to evenly remove it. Carefully look at the marks on the old and new part to be shur you do not make a mistake in the wiring. A drawing and photo might be nice too.
Apart
www.cleanfreak.com/Qstore/p001525.htm
