20 Most Recent
82 83 84 85 86 87 Chevy Camaro Billet Grille Grill Z28 Questions & Answers
Why is gas comming out of my evap canister
It sounds like the fuel tank;s VENT line hose has become swapped with the SUPPLY line. Fumes from the top of the tank are supposed to be delivered to through the vent line to the evap canister, not liquid fuel. Likewise the line feeding the fuel pressure regulator and then on to the fuel injectors needs pressurized liquid fuel and not just tank fumes.
Adjusting a rochester quadrajet carberator
proper adjust is tricky on these but to startadjust the 2 idle mixture screws at base all the way in then back out 3 1/2 turns. idle scew on linkage 1/4 after screw touches linkage
How to reset automatic sliding door on chevy venture van
The rear side door actuator control modules monitor the power sliding door positions at all times. Whenever the battery positive voltage supply to a rear side door actuator control module has been removed or the on-board diagnostics have been activated the power sliding door system(s) must be re-initialized. Re-initialize the right or left power sliding door systems using the following steps:
- Turn the ON/OFF switch for the power sliding door system to be re-initialized to the OFF position.
- Manually open the power sliding door completely.
- Manually close and latch the power sliding door.
- Turn the power sliding door ON/OFF switch to the ON position.
- Open the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
- Close the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
9/9/2022 4:43:40 AM •
Chevrolet...
Answered
on Sep 09, 2022
Check engine light on says p2000 on code reader
The code is: P2000 NOx Trap Efficiency Below Threshold Bank1 and I do not know what that is unless it has something to do with the oxygen supply to the engine. Sorry I am not much help.
10/30/2015 6:24:22 PM •
Chevrolet...
Answered
on Oct 30, 2015
