20 Most Recent
OKI C3200n Led Printer Questions & Answers
When the paper prints, the color is missing in
Inspect the rollers for dirty or damaged surfaces. Clean up any loose toner or other debris in the machine. Note: avoid touching any roller with bare skin; especially in the fuser section or the photosensitive drum in the toner section. Skin oil can cause poor print quality or premature degradation of the roller surface.
Okidata C3200N
It would help if you said where the paper jam was. However the fact that it was ok until you cleared the jam indicates you have knocked something out of place. Its just possible one of the high voltage contact springs that touch the drums has stuck in and no longer makes contacts with one of the drums. Make sure all the semi circular springs move in and out freely. Also check the led heads in the top cover. Make sure all the cables are seated in the heads ok. Make sure all the heads are in the same position and one has not turned around. Retrace your steps as your drums seem to be problem.
Oki Printer c3200 error code
Suggest you order a black drum, which may include a black cartridge. Replacing BOTH the cartridge and the drum should solve the sensor problem, then you can swap parts to isolate where the problem is.
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
How do i print borderless
you cant. laser printers (or led like oki) or more specifically dry toner electrostatic printers always have a margin to prevent the paper from jamming. the only way to print "full bleed" is to put paper in that is bigger than what you need, print the image, and trim it down.
