20 Most Recent
US Logic DVD800P Portable DVD Player Questions & Answers
Overvoltage LOGIK LOGPD1008E +24V.
If I understand correctly you have put 24V DC on the DVD player? If this is so, then unfortunately, it will most likely be totally destroyed? Most things I get in my workshop that have been subject to even a small over-voltage, say 6V - 9/12 v, are totally wrecked, so in a DVD such as this 24V would destroy almost all the logic chips, that work on 5V DC, and may others as well as other electronics too.. Most likely it would be beyond any economic repair?
However the only real way to tell is to use testing equipment to do this, also too a service manual would have to be obtained as well.
If one took the device to a service center and asked for a "Quote" as to cost and weather it's economically worthwhile to repair, wouldn't be a bad idea at least this way you would know for sure.
My logik lpd850 portable dvd player is turning on
the fault is obviously from the laser (lens) of your player. The lens is very weak such that it cannot load/read data on discs.
The best to do now is to replace the lens and your player will play all discs again.
Take care.
I Have Lost My Remote To My Studio Standard RS-912
If you have switched off it by using power button to its remote control, you must have its remote control to switch it back on. Anyway, try pressing the Ch up or Vol up buttons once. In rare cases, this might make it switch back on.
I need a replacement remote control for JVC NX-BD3 network media system
If you wish to get setup codes, three
digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to
some popular model remote controls are given. Select the 'Timeslide'
option from the drop-down list by the 'Sidebar' at the display
window. It will make search easy.
What is the universal remote
To setup so a firestick could control my Mastertech tv when I tried element from the brands to choose from it worked like a charm for on/off control, volume and mute controls from the firestick. So you might try using Element as a brand or the codes for Element tv's. BTW, I went through several brands before I landed on Element which worked.
Program codes for symphonic dvd player
Hi David, indicate the brand and model of the team you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola David, indica marca y modelo del equipo que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
