20 Most Recent
Pioneer AVH-P5700DVD Car DVD Player Questions & Answers
Error-2-99 showing on my dvd
the lens on the laser maybe fogging and will need cleaning or you may need to replace the laser because it's not as effective as it used to be, the lens is mounted on a delicate spring which when electrified moves to focus on the dvd and in time the spring gets stretched and therefore becomes less effective and there ends our lesson for today, I hope you found this helpful
11/27/2015 8:25:12 PM •
Pioneer...
Answered
on Nov 27, 2015
IS THERE A WAY TO RESET OR RECALIBRATE THE TOUCH
Well you should have a calibration setting in the menu's. However if you can't use the touchscreen there should be another way to re-calibrate it. Here is the Owners Manual. http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/212667155AVHP5700DVDOperationManual.pdf
Try the reset deatiled on Page 14, I'm sorry but other than that re-calibration is not detailed in the manual.
Was it working fine before it was de-installed
10/5/2015 6:45:42 AM •
Pioneer...
Answered
on Oct 05, 2015
Stereo wont turn on only red light is blinking
It sounds as if you are lacking accessory power to the unit. Insure that the red wire of the Pioneer unit is receiving 12 volts with the key in the accessory and on position.
6/27/2015 6:25:47 AM •
Pioneer...
Answered
on Jun 27, 2015
How can I fix my screen
Check to make sure the unit is getting good power and ground. If it tries to retract and fails, the mechanism may be jammed.
1/11/2015 11:06:41 PM •
Pioneer...
Answered
on Jan 11, 2015
