20 Most Recent
OKI MICROLINE 320 Turbo Matrix Printer Questions & Answers
I have an oki microline 320 turbo printer at work.
Is this a networked printer? You may need to reload the print driver into your computers. Most printers are generic enough that computers will recognize them and automatically install the drivers. Sometimes you need to go to the manufacturer's website and download the drivers you need.
I use a power inverter to power my printer and the
Well it sounds like the old inverter had a problem with regulation and it has inturn blown the power supplies in both printers. Without buying new PSU's there is nothing you can do. The Switch-mode power supplies in most printers do not like unstable input and that is what your inverter gave them.
Okidata Microline 320 turbo problem
Solved this problem by going into the bios and changing the port from ECP to EPP, and then uninstalling the ECP port in device manager and replacing it with a standard parallel port configuration, no problems since doing that.
Why won't it print?
need more info. is it hooked up usb or parallel? Are you printing from windows or like an AS400 or OS X. What error is the alarm light blinking or just stays on?.
Documents wont feed
If not using track feed paper this printer should have a setting for paper height. If its set too high the
rollers wont grab the paper. Also look for any paper that might be jammed or caught up in any of
the roller mechanics.
