20 Most Recent
Toshiba Tecra M11S3410 I3330M 213G 2Gb 320Gb Dvdrw 14In W7p PTME0U00N00T PTME0U00N00T PC Notebook Questions & Answers
Hi, I have a toshiba tecra m3, it boots fine and
Try connecting it to an external monitor, it could be that your laptop is either set to display through an external monitor or it could be set on a screen size too large for the laptop screen.
Toshiba Tecra R85. CMOS battery location on it please?
is that a typo OP< R850 is it?
use you tube, key word dismantle.
or replace motherboard.
see coin cell in the process.
found it for you and is special battery rechargable it is, no CR2032 sorry
R850 found it by pretending to buy the whole mobo.
see the red x, it is bundle of batteries
like this
using the wrong battery it will explode, the users guide said that . and will.
Built in hdd error
remove the hdd and attach to desktop .
right click in my computer and run check disk in tools section in drive properties
Toshiba tecra s3 supervisor password reset
1. try with clear cmos and remove AC adapter and main battery.
2. also pls try to remove the code with password re set web site or password remove tool in hiran boot cd
Toshiba tecra no image
need more information to determine the fault. but you can remove the battery and pls plug ac adapter and also re seat the RAM. power on and test
My phone is not turning on
I have had this on an iphone 5. Apple sold me a new phone as it was not worth repairing and it was out of the 12 month warranty. Its possible to order a new part and do it yourself but unless you are totally confident and have the skills to open up your phone and reassemble it then its just not worth it.
Tecra s10 display brightness
look closely at the keys along the top of the keyboard (usually called F keys). one of them should have a tiny sun icon and the key beside it will have a larger sun icon. hold down the "Fn" key elsewhere on the keyboard while pressing the one of the sun icon keys to brighten or darken the picture. the sun icon keys may also be located on the Arrow keys (<-- --> etc.)
How to remove dvd drive
When does it open on its own?Sometimes it is easy to be press the open button as you close it which of course opens it straight away.It can also fail to lock closed if not opened further than its initial amount that it does open.To close it after it opens you need to draw it back to rearm the mechanism.
PCI Express Error
You might try taking the battery completely out for about 60 seconds, and see if this does not reset whatever got hosed. Also, unplug any external devices (like wireless keyboard/mouse, SD card reader, ...) that may be trying to use the PCI buss, just in case something is hosed with them.
How to troubleshoot a non display laptop?
if you can plug in an external monitor and it shows on the external display then either the laptop screen is damaged or you have switched the display to external as default. If nothing shows then it may be a motherboard problem.
