20 Most Recent
Whirlpool DU1010XTX Builtin Dishwasher Questions & Answers
Model du1010xtxq1 will not drain?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
12/4/2010 7:13:49 PM •
Whirlpool...
Answered
on Dec 04, 2010
Wonderful Whirlpool Washus Interuptus!
My plan was to see if I could find you a service manual, but strangely, the only reference to that model number is your post here! My guess is the D6 is 'D for Dishwasher' and 'Series 6' or 6 models in that current series.
If the machine has been laid up or little used, check all the connection on the control board. Clean pins and plugs with electrical switch cleaner
https://www.google.com/search?q=DU940QWD6
8/26/2023 5:52:50 PM •
Whirlpool...
Answered
on Aug 26, 2023
How would I get access to whirlpool dishwasher pump?
Miniplayer (i)
We'll also want to shut off the inlet watersupply and disconnect that as well.
0:30/8:42
Please refer to youtube " Whirlpool Dishwasher Repair - How to Replace the Pump (Whirlpool # W11032770) "
3/23/2023 7:01:32 PM •
Whirlpool...
Answered
on Mar 23, 2023
My whirlpool dishwasher model # WDT780SAEM1 makes a loud popping noise when I open and shut the door. What is causing it and how do I fix it?
The loud popping noise that you're hearing when you open and shut the door of your Whirlpool dishwasher (model # WDT780SAEM1) is most likely caused by the door gasket. The door gasket is the rubber seal that runs around the door, creating a tight seal when the door is closed.
Here are a few things you can try to fix the issue:
- Check the gasket for damage: Inspect the door gasket for any tears, cracks, or other damage. If you find any damage, you will need to replace the gasket.
- Clean the gasket: Over time, debris and food particles can accumulate on the gasket, causing it to become stiff and not seal properly. Clean the gasket with a mild detergent and warm water, and then dry it thoroughly.
- Check the door alignment: Make sure that the door is properly aligned and not hitting the gasket when you open and shut it. If the door is not aligned properly, you will need to adjust it.
- Lubricate the hinge: If the door gasket is in good condition and properly aligned, the problem may be with the hinge. Try lubricating the hinge with a silicone-based lubricant, as this can help to reduce friction and noise.
- Contact Whirlpool: If you have tried all of the above steps and are still unable to fix the issue, contact Whirlpool customer service for further assistance. They will be able to provide you with additional troubleshooting steps or advice, or they may need to send a technician to repair or replace the dishwasher.
It's important to note that if the popping noise you're hearing is accompanied by other symptoms, such as leaks, then it may be related to a different problem, and you should contact Whirlpool customer service or a professional service technician for further diagnosis and repair.
1/14/2023 1:48:41 AM •
Whirlpool...
Answered
on Jan 14, 2023
