20 Most Recent
LuckyWire Questions & Answers
Luckywire keeps crashing. i got
I wanna tell everyone who using luckywire that is about internal error. When you open in first time, you must face with that problems but when you open second time you will not face. But in second time , you should close when you finish finding and you download something. But don't exist only click cross(x) close sign. It will be helpful.
1/17/2012 2:58:53 AM •
LuckyWire
Answered
on Jan 17, 2012
How do i get itunes
To get music to burn in iTunes it has to be imported first. Try scanning the computer for music from the iTunes menu.
Jim
5/1/2011 5:39:46 PM •
LuckyWire
Answered
on May 01, 2011
Luckywire isn't connecting. I tried
Depending on your ISP, you may have blacklisted and blocked. Yes, your ISP can see what you're doing and shut you down if you're using a P2P and it's very easy to spot. My company acts as an agent for an ISP and we do it a dozen times per week at extended stay hotels.
4/25/2011 8:15:43 AM •
LuckyWire
Answered
on Apr 25, 2011
Keeps saying no internet connection
may be problem with internet connection
reconfgure the internet settings
check for vieuses in PC
reinstall the browser
thanx
PLZ VOTE PLZ VOTE PLZ VOTE PLZ VOTE PLZ VOTE PLZ VOTE
4/7/2011 10:58:03 AM •
LuckyWire
Answered
on Apr 07, 2011
Wont connect and keeps saying
Computers that connect with wireless signals transmit to allow capture from an alternate device within vicinity either server computer for example. Observe that the computer is functioning with available signals least attaining another device that has program features. In the situation that several computers at an area share network resources, wireless signal display as appearing least capturing resouces is indication of regular functionality only requires operator to request media resources from a recogniseable device. For example, the network establshiment that were an establishment gaurantees resources. in the instance with estabshing wireless requires recognising an alternate device to derive resourcefullness. Gaming devices that captures wireless signal make transmission attainable.
2/20/2011 3:12:32 AM •
LuckyWire
Answered
on Feb 20, 2011
I open LuckyWire, and it
mine is doing the same thing! I have no clue whats wrong with it and cant fix it have you found a solution?
2/18/2011 10:24:10 AM •
LuckyWire
Answered
on Feb 18, 2011
I open LuckyWire and it keeps saying "An instance
I would do a CTRL-ALT-DEL and look at the processes running. If you can identify the process associated with that program, terminate it and you'll be OK.
Sometimes a program stops running and you can't see it on the task bar, but it's process is still running.
var fctb_tool=null;
function FCTB_Init_d362655cb7f747479026eb127d6c68fb(t)
fctb_tool=t;
start(fctb_tool);
2/3/2011 3:19:23 AM •
LuckyWire
Answered
on Feb 03, 2011
Its not connecting to internet
do you remember if you agree to allow connection to this site (when you first installed it)./ if you can get to all other sites. Find your firewall and allow Limewire......if you cant find the allowance on your firewall uninstall Limewire and re-install this time allowing its connection
1/22/2011 4:59:28 AM •
LuckyWire
Answered
on Jan 22, 2011
Mi luckywire no se abre
Hola Juan
Esto es lo que lo intentaría.
Desinstalar Luckywire en el panel de control en agregar o quitar programas.Luego de descargarlo de nuevo y volver a instalarlo. Lo siento si mitraducción al español no es clara.
Si esto ayuda a resolver su problema, ¿podría tasa de la solución. Si esto noayuda, por favor dejar un comentario darme más información sobre elproblema y voy a tratar de ayudarle.
12/29/2010 7:13:42 PM •
LuckyWire
Answered
on Dec 29, 2010
It does not connect
This Is all you need to do to have luckywire .
1. Install Java Runtime
2. Install Luckywire
3 Wait Til The Time Around 12pm - 12am Thats the times the servers usually are up
Nothings wrong if it says messages like, "Luckywire is Running" Or In Luckywire it Says "May Not Be able To Get All Results" This Is An Instants That Luckywire Is Already In Process Either Go To The Taskbar Quick Launch And Click And Open It From There Or Press Ctrl+Alt+Del and Go To Process To End The Luckywire Program. And The Other Probelm Is Just That There Is No Servers Running To Download The Sogs TRY AGAIN LATER.
In Some Cases You Have Java Runtime On Your PC And IT Still Dosent Work Just Go And Re Install It
12/25/2010 1:47:34 PM •
LuckyWire
Answered
on Dec 25, 2010
