20 Most Recent Microsoft Excel for PC Questions & Answers
5answers
How many formulas we can use at a time in Excel
That depends on which version of Excel you are using.
Excel 2003 supports up to 65,335 formulas
Excel 2007 has no limit.
you can communicate between the worksheets which are contained by one workbook (one excel-file).
Communicating between files cannot be done with formula's.
10/29/2023 8:30:07 AM • Microsoft Excel... • Answered on Oct 29, 2023
3answers
Forgot password
i have problem of to open file because of forgot file password to open
5/26/2020 12:35:14 PM • Microsoft Excel... • Answered on May 26, 2020
2answers
Sir,
use nitropdf. its best software to handle pdf convert. download here
2/18/2020 7:29:56 AM • Microsoft Excel... • Answered on Feb 18, 2020
2answers
Hi..
Download this pdf, and it will help you get started with Excel.
www.whitman.edu/geology/winter/Excel.pdf
12/20/2019 10:41:58 AM • Microsoft Excel... • Answered on Dec 20, 2019
2answers
How to convert an PDF Excel file to Excel original shape
use nitropdf to convert it back. download here
11/25/2019 11:59:17 AM • Microsoft Excel... • Answered on Nov 25, 2019
4answers
Cannot open file. Error message reads: Excel cannot open
Use Excel Repair Toolbox is efficient corrupt XLSX file repair software, suitable for all data recovery activities, applied to Microsoft Excel documents. For more: https://www.xlsxrepairtoolbox.com/
10/19/2019 10:28:39 AM • Microsoft Excel... • Answered on Oct 19, 2019
Day ending balance in bank statement
Here is the best answer for you all guys check this Missed call numbers for All Indian bank balance check in India.
8/26/2019 9:42:59 AM • Microsoft Excel... • Answered on Aug 26, 2019
5answers
How to repair and recover corrupt MS excel file?
Excel file can be repaired manually if it is less corrupted but Open and Repair program doesn't work if highly damaged due to corruptions. I searched for solutions to repair corrupt Excel file and found one solution which is full of information and provides a guaranteed solution. I am sharing this solution with all the users -Excel Repair Toolbox. Follow the exact steps given in this programm and you will be able to access the data. Download Microsoft Excel Repair tool
3/18/2019 9:56:02 AM • Microsoft Excel... • Answered on Mar 18, 2019
3answers
What is excel
Microsoft Excel is a commercial spreadsheet application . It features calculation, graphing tools, pivot tables, and a macro programming language called Visual Basic for Applications.
Microsoft Excel has the basic features of all spreadsheets, using a grid of cells arranged in numbered rows and letter-named columns to organize data manipulations like arithmetic operations. It has a battery of supplied functions to answer statistical, engineering and financial needs. In addition, it can display data as line graphs, histograms and charts, and with a very limited three-dimensional graphical display.
Regards,
Shrey
5/8/2018 6:57:12 AM • Microsoft Excel... • Answered on May 08, 2018
5answers
How to use vlookup in openoffice using different sheets
=VLOOKUP(A2;Sheet1.$A$3:D27;2;0)
The cell I created this formula in was Sheet 3 Cell C9 - to show the different sheets
A2 is the cell I want to look up
Sheet1.A3:D27 is the range of cells that contains the data I want to return, The first column relates directly to cell C9 is Sheet 3. I locked the first cell in my range as I wanted to apply the same formula across other cells hence the $
2 is the number of the column that has the data I want to return, I had a choice in this formula of 4 columns
0 is the value to complete the formula
5/2/2018 9:14:26 AM • Microsoft Excel... • Answered on May 02, 2018
2answers
Minimize Data Entry
I will suggest you to create small application in .net for ths which will add some value and process your data;If you want to use Excel only make a master sheet with details and use it in other excel sheets
4/7/2018 6:47:57 AM • Microsoft Excel... • Answered on Apr 07, 2018
2answers
HOW TO HYPERLINK THE FORMULAS IN PRESENT SHEET1 OF
1. You can do it by-inserting a hyperlink and from the "insert hyperlink" window, select "place in this document" from the "Link to" pane. Then you can select desired destination sheet
2. First from unlock all cells from the format-protection menu.
then lock only those cells which you want to restrict access to the users.
then if you are using Office 2007, from the "review" tab select "protect sheet" then uncheck "Select locked cells" check box.
click ok then you are done.
2/16/2018 7:01:35 PM • Microsoft Excel... • Answered on Feb 16, 2018
Pls give solun of rupee
First download foradian currency font and install in windows then configure currency format in Tally to Indian and select Indian Rupee symbol from the list.
9/16/2017 11:24:13 PM • Microsoft Excel... • Answered on Sep 16, 2017
How to protract a single row in excel 2007
1. First Select entire sheet -->Right click on any cell -->Cell formatting --> Protection -->Uncheck Lock 2. Now Select the desired row -->Right click -->cell formatting -->Protection -->Check Lock cell 3. Click review tab -->Select Protect Sheet --> Give Password twice
9/16/2017 11:21:19 PM • Microsoft Excel... • Answered on Sep 16, 2017
Need help creating a finction
Please provide exact problem statement in terms of dataset. For more clarification please mail on [email protected] with screenshots.
9/16/2017 11:13:29 PM • Microsoft Excel... • Answered on Sep 16, 2017
When copy from one worksheet to other formulas not copied, only values
Select and copy formula after "=" sign then in target Cell type "=" then paste formula and press enter. For more clarification please mail on [email protected] with screenshots.
9/16/2017 11:06:42 PM • Microsoft Excel... • Answered on Sep 16, 2017
If function with array
Here is an example:- We have to calculate result on the basis of marks. 1. Select answer range and click in formula bar 2. Type following formula =if(d5:D9>=40,"Passed","Failed") 3. Now Press CTRL+SHIFT+Enter key 4. Observe the result in answer range and formula in formula bar, notice { } braces come automatically when we press CTRL+SHIFT+Enter key for an array. excel3-yi4l5i2224qkwob0czw2k0fe-5-0.png For more clarification please mail on [email protected] with screenshots.
9/16/2017 11:00:51 PM • Microsoft Excel... • Answered on Sep 16, 2017
What is the easiest way to link several formulas from seperate worksheets?
pen both the sheets in the same window as:- 1. View Tab-->New Window --> Arrange All --> tiled 2. Open first sheet in first window and second in second window 3. now create formula simply by clicking in corresponding sheets and selecting cells. Alternatively you can use following format of addressing:- 1. SheetName!CellAddress (Same Workbook) 2. [WorkbookName]SheetName!CellAddress (Different Workbooks) For more clarification please mail on [email protected] with screenshots.
9/16/2017 10:48:36 PM • Microsoft Excel... • Answered on Sep 16, 2017
In Excel I have page breaks and wish to hide some pages but when printing the hidden pages print as blank pages and print preview jumps from page before and page after but includes the hidden page num
Don't put anything in blank pages, not even a space, now select the pages those you want to print and print selection. It must help you out It will locate all error containing cells, now rectify the error save it reopen in excel to see if problem is solved.
9/16/2017 10:41:55 PM • Microsoft Excel... • Answered on Sep 16, 2017
IF I ENTER A NUMBER IN COLUM A THE DATE MUST APPEER IN COLUM B AND THE TIME IN COLUM C AUTOMATICALY
it should be date and time created from that number or current system date and time ? Please clarify ...
9/16/2017 10:37:52 PM • Microsoft Excel... • Answered on Sep 16, 2017
Microsoft Excel for PC Logo
670 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Excel Microsoft
  • Excel Microsoft
Most Popular Question
forgot password
  • Computers & Internet
