20 Most Recent
ITT Night Quest 5001 Goggles Questions & Answers
I have an/pvs-7b night vision and need to replace my battery cap. The metal piece in side broke off???
Considering many vendors who sell parts are going to have a minimum order, Night Vision Depot for example has a 100 dollar minimum; you might consider trying to repair your old one or fabricating a new one. Otherwise checking on Ebay for one. On the other hand if you can fabricate a new one easily, you might consider being a vendor of that part too as you would not be the only person to encounter that dilema.
In network security + acronyms what is 3DES and definition
Triple Data Encryption Standard (DES) is a type of computerized cryptography where block cipher algorithms are applied three times to each data block. The key size is increased in Triple DES to ensure additional security through encryption capabilities. Each block contains 64 bits of data. Three keys are referred to as bundle keys with 56 bits per key. There are three keying options in data encryption standards:
- All keys being independent
- Key 1 and key 2 being independent keys
- All three keys being identical
Key option #3 is known as triple DES. The triple DES key length contains 168 bits but the key security falls to 112 bits.
What is Triple DES Definition from Techopedia
I need a manual for
Great looking product - GEN3 - much better than the Night Owl stuff from 5 yrs ago.
Not sure if you can obtain a manual for a product that is restricted by ITAR regulations.
I thought these were MIL use .
The only thing I can find is a SPEC link like :--
Operators Manual. CALL US TODAY AT: Toll Free 1-800-424-8222
http://www.morovision.com/pdf/2006/ITT_NQ5001.pdf
A reset is usually any method of disconnecting the power supply for at least 3-5 secs so the sensor can discharge into ground. Just removing the batteries should do this. -- Ray
I have a model F4975 monocular. How do I get to
Hello, do you have the ITT mini monocular? If yes, there should a cap about the size of a quarter with a slot cut into. Use a coin and unscrew the cap. I thank these mini uses button batteries but I am not sure. I don't get to see to many ITT stuff they so expensive. I'm cheap.. GB...stewbison
9/7/2011 3:29:36 AM •
ITT Optics
Answered
on Sep 07, 2011
I have a ITT nightquest
Jello, It a very nice night scope then and even to day, it American made. Those ITT 1st generation image intensifier tube have a life of about 10K hours+. If it had a few exposures to bright lights this will take a way from the life of the tube.
The only way to trouble shoot the problem is to take it parts. ITT will not provide any information on this Nightqest NV devise. You'll need someone the knows electronic in depth, troubleshoot solid state devise, and make HV ingitors for the tube in thousands of voltage. The problem could a simple passive component to the image intensifier tube has quit. Expensive to repair if the tube is bad. stewbison
8/3/2011 3:44:29 AM •
ITT Optics
Answered
on Aug 03, 2011
Pc ibm why it is so expensive?
IBM's are very good quality. I have an older IBM that I have been using for about 6 years now. It's actually much faster than most of those new computers.
6/19/2009 7:02:52 AM •
ITT Optics
Answered
on Jun 19, 2009
