20 Most Recent
Canon LBP2900 Questions & Answers
After printing first page second page printing becomes jammed every time and then I have to free jam manually
I get this problem sometimes. The quick answer is to put a large 'bulldog clip' around the stack of paper, and feed in one sheet by hand. When the sheet is almost printed feed in the next sheet.
The long term solution often is to service the 'rubber' paper feeds that get covered in dust. Use a damp cloth and press against one roller at a time, rotating a bit at a time. Not as easy as it sounds!
Then use a bit of fine 'sand' paper to remove the shiny surface on the roller(s) and wipe clean again.
Canon image class 3010 slow printting
Hi there:
The main cause of slow printing is due to a bad print cartridge. To troubleshoot this please remove one of your cartridges and see if your printing speeds up. If that does not work. Replace the cartridge and remove the other cartridge. If your printing speeds up. That print cartridge is at fault.
My canon lbp2900 printer is not print any document
Plenty of places to look at as you give me no clues! Is the power light on? If not check the power lead and power point. Is the toner OK? Is the paper OK and the paper feed working? Does your computer show it is linked to the printer?
You can do troubleshooting at the Canon website
http://www.canon-europe.com/Support/Consumer_Products/products/printers/Laser/i-SENSYS_LBP2900.aspx
Incorrect port message with canon lbp2900
Look in the Printer Properties for a Virtual USB port; an LPT1 port is a parallel port, seldom included on newer computers. The software CD should have installed a USB port, and associated the printer with that port.
