20 Most Recent
Nokia 2690 Cell Phone Questions & Answers
How to hide nokia 2690
go to menu
click on settings
click on date and format settings
select date
select first option(date on standby screen)
click on hide date
HOW TO UNLOCK SECURITY CODE
Hello Amit,
Switch off the Nokia 2690 Cell Phone. Remove the battery for 30 minutes. Reinsert the battery and switch on the Nokia 2690 Cell Phone. Enter the default code 12345 or 00000. Your Nokia 2690 Cell Phone will be unlocked.
Facebook app is not working
I also faced such kind of problem.
The one and only way to overcome this problem is you just reset your phone
Below are the steps:-
First, take the backup of your phone
And then open your num pad and Simply type *#7370#
It will ask you to reset or not then select yes
And your phone will be reset.
My nokia 2690 web Browser
If you have your internet activated on your phone but phone`s browser still won't connect, download Opera Mini browser. It`s a simple and modern browser for mobile phones.
Nokia 2690 4 5 6 key is not working
It's possible that your keypad is broken. If that is the case then your best bet would be to buy a new one from somewhere like eBay. Guides on fitting the kind of thing are readily available on the net.
I forgot my Nokia 2690 security code. How can I
SECURITY CODE:
If
you are talking about the security lock code to enter into the phone
then once it is lost nothing can be done except flashing the mobile .
Because if anybody can give the security code created then who ever who
steals your phone can get into it and get your valuable information.
So as safety precaution to avoid that they have designed it such that if
you forget the security lock you have to reset the mobile memory by
flashing the mobile at an authorized service center.So while flashing
the mobile all the data in the mobile memory will be lost and you can
again start using the mobile.
Puk code imei 353795/04/915854/4
Hi Jaimaha, If you've locked your cell phone through entering an incorrect pin number 3 times then you need a Puk code, Ring your service provider and they will give you the FREE Puk code.....
If you lock your cell phone again some time in the future and you're still with the same service provider you can use that same Puk code.. CHEERS..
MY IMEI NO.354860046784509 MUJE SECURITY CODE YAAD NI PLZZ HELP
Hi vaibhav anand if you are trying to unlock your Nokia phone from its current network go to the mentioned link and follow the instructions by the wap you will have to type the code as it is the code might have p and w in it to get these hold down on the # key. If you want to know the default phone password it is 12345 for most nokias
