20 Most Recent
Worx 17" Cordless Lawn Mower with IntelliCut 24V Model WG787 Questions & Answers
Worx 17'' Cordless Lawn Mower (Model WG787). I've
The batteries are defective in this unit. It should be returned to the dealer that you purchased it from and get exchanged, or your money back. Another way to test this mower is to charge the batteries fully, then test them. If they are truly fully charged, run the mower until it slows down, and test the batteries again. If they are still charged, (unlikely) then the problem is in the motor itself and still should be returned.
9/10/2017 2:01:00 PM •
Worx 17"...
Answered
on Sep 10, 2017
How to remove broken bit in a WORX 176L
pull locking sleeve back as shown on page 3 of instructions. pick up a can of PB blaster dry lube spray can at HD and spray some around bir.
https://www.manua.ls/worx/wx176l/manual?p=3
12/1/2023 12:23:30 AM •
Worx Garden
Answered
on Dec 01, 2023
My spool holder on my worx edger/ trimmer keeps unscrewing itself
ck out this video...https://www.google.com/search?q=spool+holder+on++worx+edger/+trimmer+keeps+unscrewing+itself&newwindow=1&sxsrf=APwXEdfauQkwFmaCtC3ubVCJYTpRDnvb2Q:1687901890446&source=lnms&sa=X&ved=2ahUKEwj70uHEtOT_AhXEg4kEHYYZAUQQ0pQJegQIDxAC&biw=1280&bih=567&dpr=1.5#kpvalbx=_NVebZNnDOImgptQP9a-08Ao_9woops..my bad. you'll have to copy and paste the link. ):
6/27/2023 9:42:40 PM •
Worx Garden
Answered
on Jun 27, 2023
Was using my 110volt worx
Your trigger might have gone bad. Take your handle apart,and check to see if you have power to the switch,you can use a jumper wire to bypass the switch to see if it starts.
6/5/2023 8:38:32 PM •
Worx Garden
Answered
on Jun 05, 2023
Trimmer. Why doesn't locking mechanism hold?
. It's very simple. You press the button on top of the trimmer. Once you press the hand grip and the top button simultaneously, you NO LONGER have to hold down the top button with with your thumb. Once you release the hand grip, you must depress the top button again. This is a SAFETY measure, so the trimmer doesn't run without a contribution from the operator
5/3/2021 12:04:11 PM •
Worx Garden
Answered
on May 03, 2021
