20 Most Recent
SE4020 2001004010 Amp Manual Starter and Charger Questions & Answers
MY Schumacher SE4020 10/40/200-AMP Wheel-Style
I researched your question and I did find a website that sells parts for your battery charger. Click on the link or paste it in to your web browser the link is below.
http://www.centurytool.net/SE_4020_Schumacher_Battery_Charger_Parts_List_s/30660.htm
I hope this helps you out and if it does please leave me a Yes that I did help you. Thank you.
11/19/2022 6:20:58 PM •
SE4020...
Answered
on Nov 19, 2022
No power to my se 4020 won't do anything
If the battery charger has been recently purchased or is still under the warranty period, have it replaced under warranty.
The retailer you have purchased it from, will know the item warranty terms / conditions.
Proof of purchase ( receipt or invoice ) is needed for repair or replacement, at the retailer it was purchased from.
Usually the retailer will warranty the battery charger, if under warranty period, but other times its the consumer that will have to speak to the manufacturer to have the warranty done, for the defective charger.
Its not advisable to try repairing the battery charger, as the electricity can kill or injure the person trying to repair it, also voids the warranty.
Have a nice day.
7/9/2016 6:05:52 AM •
SE4020...
Answered
on Jul 09, 2016
I have a 1987 Dakota
there is none. you will have to make a set of adapter plates , get some 3/8: flat steal and make a templet of the bolt holes on the block and then drill the holes in the plate and bolt the plate to the engine and set the engine in the engine bay on top of the mounts and mark the bolt holes were the mounts tuch the plates and then drill them holes and install the mounts then you will have to install a 3/8" spacer in the fan shroud to keep the fan from hitting, also you will need to swap all the sensors from your 87 engine and wirring harness they look the same but the pin location at the ECM is not the same if you plug the 88 harness into the 87 it will not run.......good luck
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
What is hashtag
hash·tag
noun
(on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
