20 Most Recent
Acer Aspire 4752, AS4752 Charger, Power Cord Questions & Answers
The hardware of backspace and enter
I would first of all try removing the keyboard, and re-seating the connection cable. If that doesn't cure the problem you may need to replace the keyboard altogether.
Power button
mimibm100, to start the system normally, don't pre the F buttons. It should boot normally. If it does not, check boot sequence in F2.
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
Acer aspire acc 603g uw30 turns on but turns back off. Help
This issue could be caused by several factors, including:
- Overheating - check if the laptop's fan is working and if the vents are clear of dust and debris.
- Low battery - if the laptop is not plugged in, try charging it.
- Corrupted software - try performing a hard reset on the laptop or booting into safe mode and running a virus scan.
- Hardware failure - if none of the above solutions work, the problem could be a hardware failure such as a failing battery or a damaged power supply. Contact Acer Support for further assistance.
Forgot password acer desktop windows 7 ultimate
If you have forgotten the password for your Acer desktop running Windows 7 Ultimate and you can't get into the system, there are a few options you can try to either reset the password or perform a factory reset.
- Use a Windows 7 installation disc: If you have a Windows 7 installation disc, you can use it to reset the password or perform a factory reset. Here's how:
- Boot your Acer desktop from the installation disc.
- Select your language and other preferences, then click "Next."
- Click "Repair your computer."
- Select "Windows 7" from the list of operating systems, then click "Next."
- Select "System Restore."
- Follow the on-screen instructions to reset the password or perform a factory reset.
- Use a Windows 7 password reset disk: If you have created a password reset disk before forgetting the password, you can use it to reset the password. Here's how:
- Boot your Acer desktop and enter an incorrect password.
- A message will appear saying "The user name or password is incorrect."
- Click "OK."
- Click "Reset password."
- Insert the password reset disk and follow the on-screen instructions to reset the password.
- Use a third-party password reset tool: If you don't have a Windows 7 installation disc or a password reset disk, you can use a third-party password reset tool, such as Ophcrack, to reset the password. Ophcrack is a free, open-source tool that can crack Windows 7 passwords. You can download it from the official website and follow the instructions to reset the password.
Note: Before using a third-party tool, it is important to make sure that it is reputable and trustworthy, and that you are using it in accordance with the law and the terms of service of your operating system.
Monitor menu not showing up on acer monitor, just input button, and no signal error message
- Check the input source: Ensure that the input source is set correctly on your monitor. You can do this by pressing the input button on your monitor repeatedly until you find the correct input source.
- Check the cable: Ensure that the cable connecting your monitor to the computer is plugged in correctly at both ends. Try using a different cable to see if that resolves the issue.
- Restart the computer: Sometimes, a simple restart of the computer can resolve the issue.
- Reset the monitor: If the above steps don't work, try resetting your monitor to its default settings. You can do this by accessing the monitor menu and selecting the reset option.
- Contact customer support: If none of the above steps work, it may be a hardware issue. Contact Acer customer support for further assistance.
